Originally posted by rocklaurence
One thing is for certain with the ARP girdle and stud kit though. While many agree it isnt the best option, it is an available and afordable one. It sure wont cause any harm and if anything, it may help a little. Plus using studs for the main caps is recomended anyways. If I ever have the money to rebuild an engine for my 95' pickup I will be using the kit.
Another thing to keep in mind is that most crankshaft failures are directly related to defective harmonic balencers. When rebuilding or transplanting a running engine, look for cracks in the rubber of the balencer or just buy a new one to be safe.
As for the gear kits....I cant say I have much info for you on that one. I have previously just used the factory chain settup with no issues. The factory sets are known to last in excess of 200K miles with few issues. Gear kits are very expensive and while they are nice, in my opinion not a necessity.
When choosing a block to start with, I would opt for a 6.2. Much cheaper and easier to find and they tend to have a better record when it comes to cracks. The later model 6.2 blocks had one piece rear main seals, while the earlier ones had a two piece. The last production 6.2 blocks were identical to the 6.5, just a smaller bore. I think they might have been the 599 block but dont quote me on that.
Biggest thing to remember when choosing a block is look for cracks. I will not buy an engine without first inspecting the main webs near the cap bolts. Just because an engine has low miles and running, dosent mean squat. Although some blocks tend to be better than others...THEY ALL CAN CRACK. There was never a completely crack-free block.
Another option is running, tested, engines with a 30 day warranty can be bought shipped for around $1200 from a military surplus supplier called boyce equipment. These are 6.2 naturaly aspirated (non-turbo) engines.
Many options to consider when going the route of a diesel swap. Alot depends on your budget and power expectations.
-Nick
