Paint prep hell
  • elskeptico
    • Sep 03, 2003
    • 821
    Paint prep hell
    This is just a general venting post about how difficult paint prep is on these things. I had no idea.
    I underestimated both how much rust I have on my Chief and how much work it is to eliminate it. Holy smokes. I started digging into the old seam sealer (of which there is plenty) and inside nearly every inch of seam is more rust. It
    1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
    If you go lookin' for rust, you'll find it.
  • Ristow
    • Jan 20, 2006
    • 17292
    yah these things rust like the mufflers on a 70's honda motorcycle.
    Originally posted by Hankrod
    • SOLSAKS
      • Jul 25, 2016
      • 1781
      yes,
      and I have always said a paint and body man
      earns every penny they make.
      it is a bear but the hard work will pay off
      always heard it said that
      a paint jobs success is 95% what is under the paint,.....the prep.
      • Crankyolman
        • Sep 27, 2017
        • 891
        I ran into the same thing on my truck, it was a huge pain but eventually you will get there and have something to be proud of.
        '72 J4500
        • brielly
          • Dec 30, 2002
          • 1076
          Yup, get ready to scrape every bit of that seam sealer out. Unfortunately you wont be able to remove the rust deep in the seems so some por15 or equivalent would be good to put in those areas before the new seem sealer. Good luck, your hard work will pay off.
          For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email [email protected]
          1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
          1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
          • Tripwire
            • Jul 30, 2000
            • 4656
            just wait till you remove the windshield i almost puked when I pulled mine
            Abort? Retry? Ignore? >
            • rang-a-stang
              • Oct 31, 2016
              • 5512
              Oh man, and all the little lines, and curves, and angles. When I see a FSJ with arrow straight lines and perfectly flat areas that are supposed to be perfectly flat, I know someone spent years of man labor sanding on that rig.
              Chuck McTruck 71 J4000
              (Chuck McTruck Build Thread)
              00 Baby Cherokee
              • elskeptico
                • Sep 03, 2003
                • 821
                I knew I'd find solace here. I appreciate the encouragement. Full steam ahead. Starting body filler this week!
                In each corner of the windshield frame, there are these square pockets, and I don't know what was filling them before, whether it was seam sealer or part of the sealer that's used with the windshield seal. Anyone know if these should be filled in?
