It must be nice to have a garage with room in it to work.
J10 6bt 5.9 cummins conversion
The motor mount pics will be up this weekend as I fab the crossmember onto the stock motor mounts. I have them on right now but I put the motor to low. I wanted to keep it as low as possible for the handling aspect and towing but it will be about a inch or two higher after this weekend. As for the garage I like to keep it uncluttered and clear so I can walk around the truck lol. Any parts or anything that is not a tool goes in the shed.1981 j10 cummins diesel Daily driver UP AND RUNNING!
1979 J20 PARTING OUT SEE PARTS FORUM
1979 Cherokee widetrack up on blocks.
Dont worry about the pic placement. But if you want to clean it up so its to your liking after you post up you can use the EDIT button at the bottom of that particular posting and once inside it you can copy what you want moved and then paste it where you actually want it, then delete where it was before.
As far as your 6BT goes ... I'M SUBSCRIBED!! You're off to a great start. Keep us updated, with pics too of course.
I'm gonna be picking up my J-truck in short order and after dragging it home begins the slow transformation. My "shop" isnt as clean as yours, but it'll hafta do. I had intended on a 4BTA, but just might make the jump to the 6BTA instead.
Cant wait to see what you have got going on this weekend!Originally posted by will eKeep in mind. Getting old is easy. Being old is hard.
What front springs did you use? Looks like they are holding all that motor up pretty well. You going to go high steer with the SOA front?
Zack
Looking great and thanks for the motor mount pic's!Jason in the Mountains
1978 J10 LB,OE 4-speed,4:10's,4BBl,and just 85K(daily driver)
1988 Grand Waggy 8" lift 35" A/T's (under construction)
1984 CJ7 12" lift 39" Iroks 1 tons
1979 Cherokee Super Chief (under construction )
1974 J-10 LB Buick 455 BB 4" lift 33" BFG tires
1973 J-4800 LB plow truck 7" lift 255/85/16 LT Truxs MT's
Originally posted by zmjeepsWhat front springs did you use? Looks like they are holding all that motor up pretty well. You going to go high steer with the SOA front?
Zack1981 j10 cummins diesel Daily driver UP AND RUNNING!
