Old 01-12-2021, 03:53 AM
Brynjminjones's Avatar
Kick Panel Template
The kick panels in my 1991 GW have been missing since I've bought it; I'm guessing they were ruined by the leaking windshield.
I'd like to get some replacements but can't really justify spending the cost of shipping from the US, so I'm thinking about cutting out my own.
Does anybody have some kind of template or drawing I could use as a guide?
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 01-12-2021, 08:18 AM
Do what the pros do and make one out of paper of light board material, then trace it onto a sheet of ABS or whatever material you're going to use. Make it slightly bigger than the area so you can trim it down to proper size.
--Rob--
My build thread:
Old 01-12-2021, 09:20 AM
Good idea, thanks!
I've also realised that TGW have a good 2d view of the shape, so if I can take a couple of reference measurements I should be able to trace it out.
1974 Ford F100 390
Old 01-12-2021, 09:57 AM
BJones,....
I had gotten the ABS kick panels from MIB on the forum,...
decided not to use them
I used carpet instead.
not best idea for some situations.
but for mine,... ok.
as u know the rugged material takes more abuse and easier to clean.
let us know how you end up doing it.
dave in nc
Old 01-12-2021, 03:04 PM
SJTD SJTD is online now
I wasn't impressed with the factory painted cardboard stuffed under a sheet metal bracket. More lipstick.
I figgered to use whatever material I have the door done with, some padding and tuck it under the door seal and carpet.
Don't forget to remove the air vents down there and clean the leaves out.
Old 01-12-2021, 04:06 PM
BTW, BJ's kick panels are pretty decent @ $34.90 for the pair.
I bought the black plastic ones with the grain and had to trim them down some to fit correctly, and drill the holes for the hood release.
What's shipping across the pond cost you?
--Rob--
My build thread:
Old 01-12-2021, 05:46 PM
letank's Avatar
letank letank is offline
I can post a pict with some measurements, I have both sides out of the cab, sitting in the paper template bin.... You need the layout for the fresh air vent.
I can probably scan it, and send you or post the scanned document as a pdf...
Old 01-12-2021, 06:30 PM
Tripwire's Avatar
Tripwire Tripwire is offline
yes get ahold of MIB, im sure he would be willing to trace out his plastic inserts on a piece of paper and mail them to you - he is a good guy
Abort? Retry? Ignore? >
Old 01-13-2021, 12:51 AM
letank's Avatar
kick panel
the panel is longer than a regular scanner:
here are 2 scans pasted with measurements in inch
the left side is missing the bottom part, but has the holes for the emergency brake or parking brake fix points, of course on the other side of the pond, the parking brake is somewhere else...
Old 01-13-2021, 04:33 PM
Honchov8 Honchov8 is offline
FSJ kick panels
I used a close cell foam craft sheet (so it won't absorb water) to make mine. I had purchased a set of the ABS Kick Panels from BJ's and I wasn't impressed with them but I did use them as a template. I then went to Joanna fabrics and purchased a few thin black closed cell foam sheets and traced the kick panel outlines on them. I then simply cut out the close cell foam with scissors. The foam is very easy to work with as its' pliable and tucks into the bottom retaining bracket easily. They've been in the truck for over 3 years now without issue.
1976 J10 Honcho "Z" code
Old 01-19-2021, 07:17 AM
Cliff's Avatar
Cliff Cliff is offline
I just painted mine. I ground off the tabs and smoothed it with a little bondo. Cleaned out the vent area, cleaned up a little surface rust, and painted the kick panels with Rustoleum Royal Blue, which is a great match to my blue interior. Applied the paint with a 2" foam roller. Looks great!
Cliff Danley
1977 Cherokee S
Vents, kick panel airman General FSJ Tech 9 01-23-2017 01:53 PM
Drivers side, air vent water leak...kick panel..?#?#!$! JPUCK General FSJ Tech 5 09-16-2006 01:22 PM
Kick Panel Carpet coolram General FSJ Tech 2 02-08-2002 12:36 PM
Kick Panel Water Leak Coley General FSJ Tech 23 06-19-2001 08:39 AM
kick panel lights ironroad29 General FSJ Tech 2 05-23-2001 01:26 PM
