Old 10-01-2022, 01:10 PM
crisd crisd is offline
Advance Auto Ign Mod looks like cheap crap
Hi all,
Perhaps I'm not up to date on the latest technology but from just looking at the brand new ignition module from Advance Auto (label on box CBG1031, stamped on module TRANSPO-CN FM700-17921) it looks like cheap junk. The aluminum shell is the same but when you turn it over it isn't filled completely like the old one, it is only filled about 1/4 of the way. See pics. I don't pretend to know about the latest advances in electronic technology but this looks pretty suspect. Does anyone know why this is so and should I return it and go somewhere else for a new ignition module?
[attachment=0]Ign Mod compared.jpg[/attachment][attachment=1]Adv Auto Ign Mod.jpg[/attachment]
Old 10-01-2022, 01:32 PM
pretty much any brand is inferior to oem the module.
they're not a maintenance item, meaning ONLY replace if it's dead.
standard motor products lx235 is probably the best made today?
whatever brand you buy make sure it has a lifetime warranty and expect to replace it.
A good used original module would be my preferred choice.
Old 10-02-2022, 10:07 AM
new Advance Auto Ignition Module is junk
Well I decided to hook it up and it didn't start. I pulled a plug wire and connected a spark plug to it and grounded it to the block. My son turned the key as I watched... no spark. I re-connected the old module and... spark. So I'm returning the new module... its junk.
Old 10-02-2022, 10:13 AM
And that is why I stated do NOT replace an existing one with a new one unless it's dead.
Today's aftermarket electronics are right outta box or fail in short order.
Old 10-03-2022, 06:59 PM
fastjeep fastjeep is offline
This summer had no spark conditions with mine. Tried old original boxes I had saved and would work but if had to idle in traffic would just shut off. I even had made a ignition box with a GM 4 pin HEI module but just couldn't get the heat sink to get rid of heat. Finally converted to a MSD box. Ever since then no problems
Old 10-04-2022, 01:09 PM
My son's 86 Ranger went through 4 bad modules, straight out of the box before we got one that worked. They are all garbage.
I am with babywag.
Originally Posted by babywag
...whatever brand you buy make sure it has a lifetime warranty and expect to replace it...
I would keep buying modules until you get 2 that work. Put one in your glovebox and keep the receipt with it. Then when you are stranded somewhere with a dead box, you swap with your spare, and go return the turd, get a new one, verify it works, then throw it back into your glovebox and expect to do this every 2-12 months.
Also, replace the green gross connectors.
00 Baby Cherokee
Old 10-04-2022, 06:32 PM
By chance did you check the wiring at the connectors to make sure they were not pinned in a different order? I have found a lot of the Chinese electrical parts wired in a different pattern, swapped around pins and they worked.
Old 10-05-2022, 07:43 PM
No, I never checked the wiring, I've already returned it so I can't check now. But I'll keep that in mind for the next time.
Advance Auto worth visiting? lkmarsh General Chit-Chat 8 05-19-2021 03:57 PM
Edelbrock 1406 Vacuum Port Question etprime General FSJ Tech 7 01-01-2015 09:51 AM
Steering Wheel Play - New Steering Box? Lyman DeKoquonut General FSJ Tech 47 12-17-2004 10:06 AM
Creative Cooling? Manhattan General FSJ Tech 31 06-02-2002 09:25 AM
