Old 04-19-2017, 01:05 PM
m0rgant0r's Avatar
m0rgant0r m0rgant0r is offline
Noob!
KJ-65 Automatic Transmission swap
Hello All,
When i picked up my '65 Rhino it came with a spare Automatic Tranny that the owner ordered specifically for the truck. The tin name badge says "KJ-65- 5395" on it and it came w/ a torque converter. Thing is when i looked at my 327 this weekend the starter is on the passenger side and on the transmission the starter lobe is on the driver side. I noticed that the block has cutouts on both sides for a starter but the oil filter is on that spot. so...
1. Is this the right transmission for this truck?
2. Is there a remote oil filter setup to move that out of the way?
3. Can i swap the starter to the other side wo/ too much hassle?
Thanks,
Morgan in SF
Fastener Removal Expert!
Old 04-19-2017, 01:18 PM
Stock AT would have been the TH400 with the Buick "nailhead" bolt patten and used with a factory adapter to bolt it to the 327 bolt pattern. Yours might be stock. Been out of the Chev loop a long time but the kj-65-5395 ID number sure sounds like it could be a GM built TH400 ID number for a trans used by Kaiser. I've got a book buried somewhere in my house with GM AT number translations. If I find it I'll get back to ya.
Old 04-19-2017, 01:19 PM
m0rgant0r's Avatar
Noob!
More Details...
Looking here...
http://www.jeep-cj.com/articles/powe...nformation-71/
It does resemble a TH400 but again w/ the Starter kickout on the driver side. It mounted to a transfercase w/ the weird Wagoneer "bent" 4WD lever on the top.
I also found an auto shift column, NOS flex plate and oil cooler... so, thoughts?
Old 04-20-2017, 10:31 AM
m0rgant0r's Avatar
Noob!
327 adaptor kit info
So seems i need to track down a 327 to TH400 adaptor ring. Since they're all used at this point does anyone know exactly what parts were included to set this up?
Seems the vital bits are the Adaptor Ring and the crank spacer? Nuts and bolts should all be standard sizes and i have a flexplate... anything else?
Old 04-20-2017, 11:13 AM
If it's a spare transmission, isn't there already a transmission in the Jeep? If so, you can reuse the adapter ring and any additional parts needed. Some of these TH400s with the adapter ring also used an additional adapter (crank spacer) to support the snout of the torque converter.
There is a parts catalog here http://oljeep.com/parts_man/62-73_FS...talog_w_bm.pdf that should show the needed parts. I'm at work and can't download it now, but I can look later if you have trouble finding the parts and/or illustration.
Post pictures of what you have now.
Old 04-20-2017, 12:49 PM
m0rgant0r's Avatar
Noob!
It's a manual to auto swap
It's got a 3 speed (w/ chipped teeth on the 1st) in it right now so no adaptor on it currently. I'll follow up w/ pics ASAP.
thanks for the link to the parts book, i'll dig through it at lunch.
M.
Old 04-20-2017, 01:20 PM
airman's Avatar
airman airman is offline
I have a 327 to nailhead 400 trand. adaptor, crank spacer, covers, mayb the plate that goes next to the motor, and fasteners.
Also the transmission no adaptor to the 20 transfer case.
PM me if you are interested.
Andrew
Albuquerque, NM USA
1969 J3000 Dauntless 350, T15, D20
1970 CJ6 Dauntless 350 , T350, D20
1951 CJ3A in the wings
Old 04-23-2017, 12:58 PM
m0rgant0r's Avatar
Noob!
progress!
The 3 speed is out and once i get the adaptor ring and spacer should be GTG. Also, found a weaping freeze plug on the back ofthe block so will be addressing that before finishing up.
Old 04-24-2017, 08:21 AM
airman's Avatar
Morgan
The adaptor I am sending you has the starter on the pass side. There is also a spacer that goes betwene the starter and adaptor, it is in the box also.
I have a picture of it .
Andrew
Old 05-01-2017, 05:20 PM
m0rgant0r's Avatar
Noob!
U-joint Flange
Anyone dealt w/ this on the back of their Transfercase? Wondering what size driveshaft/u-joint yoke to order... looking around wo/ seeing anything that it matches up to size-wise. It's def using 1310 style u-joints.
Old 05-01-2017, 06:49 PM
airman's Avatar
Morgan
PM sent
Andrew
Old 05-08-2017, 01:24 PM
m0rgant0r's Avatar
Noob!
progress...
New Freeze Plugs...
Flexplate and adaptor ring in place... Thanks again Airman Andrew!
Not 100% finished yet, but getting there...
Manual Transmission Swap Questions G-Wag General FSJ Tech 21 03-26-2012 05:11 PM
Automatic Transmission Line Golden Eagle General FSJ Tech 8 11-01-2010 03:23 AM
79 chief Transmission swap nlrwrangler General FSJ Discussion 4 03-17-2008 07:39 AM
Question regarding floor shift for automatic transmission in FSJ soxcloud General FSJ Tech 3 03-13-2007 09:03 PM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
