Every diagram I see for TBIs just shows a line to the Check Engine/Service engine soon/Malfunction Indication light. I assumed the computer applied 12v to light the light. Or do I apply 12v to the light and the computer grounds it to turn it on?
Does my check engine light need a ground or 12v?
Chuck McTruck 71 J4000
00 Baby CherokeeTags: None
Originally posted by rang-a-stangOr do I apply 12v to the light and the computer grounds it to turn it on?
You sure you don't want to break in your new engine w/ a carb before experimenting/debugging a TBI install??Tony
Originally posted by babywagYou sure you don't want to break in your new engine w/ a carb before experimenting/debugging a TBI install??Chuck McTruck 71 J4000
PCM is the ground for the light. Back in the day, when we wanted the CEL to flash codes, we would put a jumper wire between socket A and B on the ALDL (Assembly line Diagnostic link) It's called the DLC on OBD 2 vehicles.77 Cherokee S 360/TH400/QT
Originally posted by babywag@ minimum should monitor data to try and make very certain it isn't too lean.
too lean and you risk chewing up cylinder(s) and/or piston(s).
what is your plan on a .bin?
.bin: I have one computer from a stock 95 350 and also bought this setup:
He had it on his 440 which is very similar to my build: Similar cam, similar compression, headers, timing control, etc. I know I will need to tune but his .bin should be in the ball park for me and close enough to break in the cam? I am using his injector pod now (28psi, I verified it this weekend) and computer. I hope to get into that .bin this week and see what's in there. ProTuner is all new ground for me so I have a steep learning curve. Luckily there is tons of info out there, I just need to spend the time to learn it.Chuck McTruck 71 J4000
