Does anyone know what the DMV buracracy would be for a Diesel engine swap into a 1987 GW??
Diesel swap and Taxifornia???
You really should be asking the PRC's polit bureau directly for a definitive answer before spending big bucks. And get that "in writing".
A strong sub bureau of the PRC is C.A.R.B...just ask them about dsl motors?
The only thing more critical than dsl's to C.A.R.B is the rising cost of surf board wax and canned chile dude...joe
Originally posted by Fiodh. ArgusI understand California won't let you swap a diesel into a formerly gas car, and also any motor transplanted has to be the same age of the car or newer. Your best bet is to get a 75 or older rig and then do as you please.
or am i going too far by assuming that the state of kalifornia uses simple logic?
Al79 Cherokee Chief "Kronk" - TBI350/SM465/NP205
Originally posted by AlsChopShopwhy?
I think you can re-register it as a diesel; call up an inspection referee. Years back I talked to one named Gus and he was extremely helpful and friendly.
Personally I would (and did) bypass all this BS and just get a '75 or older vehicle.
I've been considering a GM diesel swap into my Wagoneer for a while. After being bitten a couple times by the California smog laws (for instance, after having swapped a 1963 aluminum-block Buick V8 into my '80 VW Vanagon :D ), I decided to do a bit of research before throwing a bunch of hard-earned Benjamins down the toilet.John
'87 Grand Wagoneer
4" lift, 31s, 5.2L Magnum
Current Jeep status: Operational...mostly
You could always tell them it's a Family Truckster and put what you want in it, or you could move to someplace real...Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
In California, DO NOT TAKE IT TO A REFEREE !
Install your diesel engine.
Fill out this form...
http://www.dmv.ca.gov/forms/reg/reg256.pdf
Check the boxes under "B" that say "It is powered by" and "Diesel".
Go to your local DMV, have it inspected.
They will change the "G" on your registration under "Fuel" to a "D".
I understand the Simi Valley office is very good about this.
More info can be found here...
http://jeep2diesel.org/
And their message board (not very active, but good info)
http://messages.jeep2diesel.org/index.php
kris.89 Waggy
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally posted by JeepinPete-If it wasn't for bad luck, you wouldn't have any luck at all-
