Old 03-31-2020, 09:26 AM
sld's Avatar
sld sld is offline
81 Cherokee
I write this post of shame. I was planning on putting new fuel lines on my gas tank, the four small ones, not the fill. This was almost three years ago. I can not get a photo to load
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Old 03-31-2020, 11:09 AM
sld's Avatar
sld sld is offline
Two at the sender , then two more. And what did you use to turn the large nut on the sending unit?
Old 03-31-2020, 03:42 PM
sld's Avatar
sld sld is offline
The two at the sender are the supply and return. What are the other two?
Old 04-01-2020, 04:18 AM
those should be vent lines.
Old 04-01-2020, 05:15 AM
sld's Avatar
sld sld is offline
I thought one may have been to a missing emission canister of some sort.
What about the sending unit large nut? What is used to span it ?
Old 04-01-2020, 08:18 AM
Simo's Avatar
Simo Simo is offline
While I don't have an '80-up to speak from experience, it looks like your fuel sender features a big plastic hex retainer like this.
If you don't have an appropriately sized wrench, some channel locks or even a pipe wrench should be able to grab the nut without doing too much damage. As a last resort, tap it out with a punch or screwdriver. Should the part get messed up, they are replaceable for $5-10.
https://www.fsjjeepparts.com/jpsu-1.html
https://www.bjsoffroad.com/Sending-U...FSJ_p_834.html
Old 04-01-2020, 08:27 AM
Most of the '82 TSM is online here - https://oljeep.com/edge_parts_man.html - the fuel system of an '82 is comparable to an '80. Suggest you look at figures 1J-5, 1J-7 and 1J-13.
The TSM will help you a lot. You can buy a CD-ROM version from RockAuto for less than $25 - dirt cheap considering how much it will help. https://www.rockauto.com/en/moreinfo...179457&jsn=371
74 J-20 axle (or frame) swap to 79 Cherokee questions Jay-ten General FSJ Tech 5 05-04-2017 08:56 PM
Cherokee Panel In Hot Rod Menace General FSJ Discussion 11 04-18-2011 10:35 PM
Questions about 1979 Cherokee fuel tank and... Bev25 General FSJ Tech 11 01-27-2008 06:10 PM
1981 Cherokee Laredo - Tom Anhalt Dome Cherokees 0 08-21-2005 12:36 PM
1979 Cherokee - Michael Baxter Dome Cherokees 0 08-21-2005 12:25 PM
