I plan on doing this swap but with 6.5 mech inj. td. My only advise for this is never use a block that came from GM, only use GEP blocks. I have gotten mine from Teds trucks n stuff and he sells 6.2 as well from military takeout program. I have not had any issues with their engines. I don't believe mine have ever been used.
6.2l GM Diesel?
Last edited by hookedup50; 07-01-2013, 10:31 AM.Jennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
Originally posted by TnfalconerBryan I just noticed that the Novak motor mount kit is 100.00 more expensive than the Advance adapters kit. Is is 100 bucks better?
I have not not performed this swap (yet) or used these products.
However, I was a mechanical designer in a previous life, so I would like to think I know a little something.
Please understand these are my thoughts and opinions.
Your mileage may vary.
To answer your question, are the Novak Mounts worth the extra cabbage?
IMHO, Yes.
The Novak mounts seems to be engineered better, not generic in nature.
If you look at the AA mount, they are adjustable with slots.
I personally do not care for that.
What is the keep that from sliding under the torque of the engine?
Can one tighten the fastener enough to keep it in place?
I would like rigidity in my motor mounts.
I do not want my engine sliding to the passenger side of the engine bay when I make a spirited left hand turn.
I see that the Novak mounts has a few holes in the down leg of their product.
I am guessing with grade 8 hardware, that would be fine...
...but with the overkill thinking I have...once I got the mount all positioned the way I liked it, I would remove them and have it all welded up.Last edited by The PIG Smith; 01-17-2013, 06:23 PM.Bryan Smith
2017 Jeep Grand Cherokee Limited
- 75th Anniversary Edition - 1941 Trim Package - Recon Green
1986 Jeep J20
- Super clean rig from the AZ/CA state line
1982 Jeep J10
- Has become a Long Term Project.
1981 Jeep J20
- Commercial flat bed - Lost in a Divorce --gone
1987 Jeep J20 Pioneer
- Former Rick Bielec aka Ricbee plow rig. Major rust!! --gone
IFSJA Member #1933 Joined November 30, 2001
Originally posted by Jayrodoh...but if it works, I wouldn't touch it.Originally posted by LindelBest laid plans, yada yada yada...
Originally posted by The PIG Smith...but with the overkill thinking I have...once I got the mount all positioned the way I liked it, I would remove them and have it all welded up.
I've been looking at a van with a 6.2 sitting in front of a 700r4. Runs and drives. Seriously thinking of tearing it apart for a swap.Wannabe Fabricator
Grumpy on a good day.
