02-17-2009, 09:10 AM
No luck lift
My luck a guy gives me some waggy springs, I order AAL's go to install but the springs are so pitted with rust between the leaves I'm afraid to use em! Hell the mainleaf is eat up 1/4 way thru and has two waves of bendyness I never noticed so I have some worthless AAL's now.
I need a two or 3 inch lift spring for the front. Whts my options for buying individually and not a kit?
Don't say rancho 44044. Been there, bent and broke those!
02-17-2009, 10:08 AM
Post in the wanted section... somebody up close to you has some springs they'll let go for free or for cheap... then you can use the AALs you bought... if you were close to me I'd let you have a set for not much...
02-17-2009, 10:57 AM
What about running some chevy lift springs? I think if you divide what the advertised lift amount for a chevy then that is what it will lift your FSJ (6" spring / 2 = 3" of lift).
The problem is it will also move your axle forward ~1" or so from the stock location, but that also may not be a problem.
You may be able to pick some of those up for cheap, just a thought.
Also I think you can buy new individual springs, stock or lifted, from BJs if you want to go that route as well.
Rankin
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
02-17-2009, 11:31 AM
Rough Country 8004's?
02-17-2009, 12:54 PM
I would give you the ones I have but they're for the rear  Seriously, where did you bend the 44044s?
edit: also you could look at a junkyard or better yet find someone that can re-arch springs. they should be able to make you a pack to your specs for a reasonable price. If you want bling call Alcan. If you want middle of the road get Skyjacker or the 44044s. I had to weld a piece of tube behind the springs so the hanger wouldn't kick back and bend the main leaf.
02-17-2009, 02:08 PM
I think Hell Creek has stock springs too...
02-17-2009, 02:28 PM
360 AMC
I think its time you put a se of alcan's under there. Military wrapped springs...nuff said. I wouldnt worry about bending those. Prolly cost you $400 or so but will be custom made for your truck
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
02-17-2009, 03:17 PM
I bent them right infront of the rear hanger and broke the drivers side in the same place. Did it in harlan on lower ****ation in the rain. I don't recommend that trail when wet
Alcan would be my "if I had the money" choice.
F*uck it I'm gonna run em. Imtired of seeing my junk on jackstands! Ill post up a wanted add and just thrash my junk in the mean time.
DPG in march Nick?
02-17-2009, 03:51 PM
Rankin
Wait wait wait...
WHAT!?
Thats EXACTLY what I want.. 3in of lift and one inch forward axle relocation.... More details please! Does this work for the rear or just the front? How the ride quality?
02-17-2009, 05:21 PM
Rankin
You are right about the 6" Chevy springs being about 3" lift, but it doesn't work the way you said. Just minus ~ 3" off of whatever lift spring you have.
4" Chevy = ~1" Jeep
6" Chevy = ~3" Jeep
8" Chevy = ~5" Jeep
And so on....
No jeeps at the moment
02-17-2009, 05:24 PM
Originally Posted by duncanstives
Wait wait wait...
WHAT!?
I have had good luck with Tuff Country EZ-Ride 6" Chevy springs in the front. They ride decent (for a lift spring) and flex like crazy.
I don't know about the rears though..... never done that.
02-17-2009, 05:36 PM
But it provides 3 in of lift or there about?
I am hoping to avoid steering issues and I am GUESSING I will be OK with 3in (I have heard all the debates and people that got death wobble when they lifted it a half inch and those who lifted it 2 feet and had no problems... I am just willing to take a chance on 3in and see what happens)
02-18-2009, 08:00 AM
DPG in march Nick?
I hate to say it but that was my first thought. Just run them and see. In the meantime you can be on the search for others.
DPG? Haven't been there yet. I need to get out there and check it out. March may be do-able. Depends on the funds. I've got to save enough for the Tellico trip in April.
Thread Tools |
Display Modes |
