Old 01-05-2009, 10:34 PM
Guru Guru is offline
BJ's 6" lift on 3/4 ton?
So if I go with the 8 lug front/rear,will the lift kit from BJ's come in 3/4 ton springs or does that pretty much eliminate the whole heavy duty suspension?
Guru Customz Jack it to Jesus!!!
Old 01-05-2009, 10:42 PM
I got the Willys....
AFAIK BJ's lifts kits only come in one spring rate, which I would guess is something a bit over half ton spring ratings.
So yes, you would lose the HD suspension.
1971 Gladiator
Old 01-05-2009, 10:46 PM
Well................
So how do I get 35's and still get the duty?Maybe some helper air bags?
Old 01-05-2009, 10:51 PM
Custom springs up front and blocks or custom springs in the rear. I would think that a stiff spring (for weight carrying capacity) and a lot of arch for lift would give a pretty bad ride though.
1971 Gladiator
Old 01-06-2009, 10:25 AM
crazydog's Avatar
crazydog crazydog is offline
SOA in the front and shackle flip in the back.
Do you ever search and read, or just post twenty questions each day?
1967 J3500 - Making plans
Old 01-06-2009, 11:44 AM
ThisGuyUKnow's Avatar
Hey now play nice
Old 01-06-2009, 11:45 AM
COLOFIREMAN's Avatar
Shackle flip with the stock springs on most almost all J-trucks will allow you to put 35" on them. I have a 3" body lift on my 73 J4000 and I am able to clear tall skinny Swamper Truxus 33's or 255x85x16 which allows me to run chains because of frame clearance.
I also plan to flip the shackle so I can order the Hellcreek front springs. Don't plan to go to a bigger tire yet but I want to get my frame out of the snow more when I break driveways.
This truck, kaisermans I think, was able to put on 36's, or 9.50x16's, bias tires. So it all depends on how wide of a tire you want to go. I do like the ride height of this rig!
Attachment 10216
Old 01-06-2009, 12:50 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
I'm gonna assume you have a j-20. Let's be realistic here the stock springs suck. If you want 35's and a decent ride do the bj's springs. I dunno what you need a 3/4 but test out the bj's springs and see if they sag. If so bag it, or use a helper spring. if not use keep on truckin. Be sure you specify a j20 when ordering so you get ubolts to fit the 60
Old 01-06-2009, 01:20 PM
Originally Posted by 4x4fEvEr
I'm gonna assume you have a J-20. Let's be realistic here the stock springs suck. If you want 35's and a decent ride do the bj's springs. I dunno what you need a 3/4 but test out the bj's springs and see if they sag. If so bag it, or use a helper spring. if not use keep on truckin. Be sure you specify a J20 when ordering so you get ubolts to fit the 60
I agree, if you decide to order the BJ's kit, plan on bags for the rear if you carry or tow alot of tounge weight. I have a 01 Dodge Diesel and I needed to put bags on the rear when I pull heavy since I put the lift on it.
Old 01-06-2009, 01:56 PM
Yes I do search and read,but some of the questions I have asked I did'nt find what I was lookin' for.anyhow thanks for all the info.I have a J10 golden eagle but found a J20 front and rear.I work on a ranch and it's kinda handy to be able to move stock trailors and cattle around when the big trucks are bein used.
Old 01-06-2009, 05:39 PM
I for got about SOA front and shackle flip for the rear. Tons of info on that here. Use the google seach like I mentioned.
You will have to do somehitng for your steering, and you will probable need longer driveshafts for a SOA in the front.
My truck above with the 36" bias plys is about 2" above stock height in the front and 1" in the rear. The tires rubbed the front corners of the front fenders, I think I would have been okay if I had trimmed them. The rear srpigs are so stiff I never would have rubbed back there.
1971 Gladiator
Old 01-06-2009, 10:13 PM
Yep that's just right on that truck,that's where I want mine to sit.I believe I have decided to go with BJ's 6W/bags in the rear.And, I may end up going with 36".There's a certain look I'm trying for and I think that will work.I may also go with a 1" lift shackel in the rear to get a slight rake.That's one nice truck.
Old 01-06-2009, 10:24 PM
Unless you flip the rear shackles, a lift shackle will lower your ride height. Lift shackles only work for suspensions with the shackle pointing toward the ground.
1971 Gladiator
Old 01-06-2009, 10:35 PM
roger that,thanks.That means I need a shackle flip kit.
Old 01-07-2009, 10:02 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
your best / least expensive route would be the 6" full suspension and bags for the rear for when towing heavy loads.
BJ's Off-Road
ryan@bjsoffroad.com
Old 01-07-2009, 12:14 PM
Thats why I contacted you last night via PM,cause from what I hear you guys are the ones for FSJ stuff.
Old 01-07-2009, 12:22 PM
do you have the bag system as well.
Old 01-07-2009, 01:46 PM
You could also mount the type of over load springs that clamp to the top of the spring pack and press against brackets mounted on the frame.
When the main spring pack is compressed the overload spring pack is forced against the brackets and take up some of the weight.
When there is no load in the bed they don't effect the ride.
1971 Gladiator
