Old 01-17-2007, 06:08 PM
jpsterluvr's Avatar
jpsterluvr jpsterluvr is offline
Question Sources for Rock Sliders
Hey guys, does anyone have some sources for gw rock sliders?
1989 TFI, K&N, BJ's 6" lift kit with pro comp shocks and drop pitman arm, Quick disconnect sway bar links, Turbo muffler and high flow cat with new exhaust from the y-pipe back, Rebuilt tranny
Old 01-17-2007, 06:41 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
Old 01-17-2007, 07:29 PM
What the wee lad is saying in his most subtly way is there is no manufacture for rock sliders except you!
Old 01-17-2007, 07:34 PM
82j20's Avatar
82j20 82j20 is offline
dont have any finished pics but heres the start
http://ca.pg.photos.yahoo.com/ph/fsjwheeler/album?.dir=ac01scd&.src=ph&store=&prodid=&.done=ht tp%3a//ca.pg.photos.yahoo.com/ph/fsjwheeler/my_photos
burnin the bbq juice
Old 01-17-2007, 09:55 PM
armyfsj's Avatar
armyfsj armyfsj is offline
here are these from BJ's http://www.bjsoffroad.com/cartgenie/...pid=530&cid=30
JEEP STATUS: Currently Jeepless But looking!
http://www.militaryjeepers.com/
Old 01-17-2007, 10:10 PM
johnwaynejeep2
Posts: n/a
Desert Beast,
I like your rock sliders . Do you mind if I rip off the idea and build some for my Wag?
Old 02-08-2007, 01:42 AM
Beastie79 Beastie79 is offline
Red face
I have all I need but the tubing (poor student type). I DO have some 1/16th (0.0625?) 1x1's, 1x2's, & 2x4's, 1x1 1/8 angle, and a bit of 1/8th and 1/4 plate. Old tractor crates I got for free... (Not enough quarter to box with, maybe reinforce?)
What would you do with that?
I was thinking about the same design as Desert Beast's. It's a good design to copy from. I drew something, but don't know how to post it.
4 body points with the 2x4's and maybe 1/4 gussets.
A length of two 1x2's welded together replacing the 1/4" square main rail (maybe with some angle to reinforce)
Another long 2x4 across the top held on with 4 or 5 more 6" 1x2's.
Then 1/8 sheet welded on the angled up piece for strength and sliding?
If the slider gets hit hard enough to buckle then I can replace it free, as long as the jeep's mostly ok. Theory here is quantity over quality to build up strength.
Old 02-08-2007, 10:15 AM
360 AMC
i personaly would go thicker than 1/16". but that might just be me, i like to overbuild things slightly. my sliders are all .188wall.
and for the record the above pic i posted of the rock sliders is not mine. or one that i built. i just got the pic from google.
these are the rocksliders/boatside on my jeep.
Old 02-09-2007, 02:49 PM
matt thompson's Avatar
matt thompson matt thompson is offline
Exclamation
all I know is that .120 wall wont hold up on a rock without bending. prolly worse under a heavy fsj.
1988 grand wag-amc360, TF727, twin stick Dana 300, D44 front, 14bolt(10.5")
http://www.ifsja.org/forums/vb/showt...=matt+thompson
1995 wrangler YJ-stock so far
1991 cummins 12valve flatbed
Old 02-11-2007, 12:42 AM
bowtieman55 bowtieman55 is offline
Here is Rstep's rock slider buildup
Very Nice work
http://fsjnetwork.com/fsjn/viewtopic.php?t=2038&postdays=0&postorder=asc&star t=0
Old 02-11-2007, 01:23 AM
82j20's Avatar
Originally Posted by bowtieman55
thanks for posting that dude makes my square tube sliders look like shiat
Old 02-11-2007, 11:26 PM
Kaiser's Avatar
Kaiser Kaiser is offline
Trail Gear.
1965 Kaiser/Jeep Gladiator J300 7600 GVW
Old 02-12-2007, 10:47 AM
I did some calulations (Read: Hit the steel with a sledge hammer). 1/16 will not do. Even double welded and reinforced. Don't skimp, and do it right. As my friend commented: "You just made a damage multiplier."
The welds held, but the box just crumpled after 2 or 3 hits. Nice sharp bends to dig into the rocker pannels....
I guess this is for any other new guys that read this later.
