Old 02-18-2015, 09:04 PM
GWD6's Avatar
GWD6 GWD6 is offline
Howell Install advice?
Within the next couple of weeks I'll be installing a new Edelbrock Performer Intake Manifold (with EGR) along with the Emissions Legal Howell TBI kit on my 1984 Grand Wagoneer.
I'm fairly mechanically inclined and plan on doing this solo. The only thing I'm going to need outside help on (I think/hope) is welding the Oxygen Sensor bung on the exhaust.
If any of you that have already installed this system can offer any pointers I would sure appreciate it.
Thanks
'84 Grand Wagoneer
Old 02-19-2015, 05:11 AM
Texas Walter's Avatar
Texas Walter Texas Walter is offline
I also plan to do the same one day so Ill be fallowing this looking for advice
Old 02-19-2015, 05:46 AM
men in black's Avatar
I needed to install a new y pipe, so I had the bung weld on first.
Addicted is installing my Howell TBI over the winter.,
Old 02-19-2015, 06:24 PM
blthomas's Avatar
blthomas blthomas is offline
Noob!
I was looking at their systems online. Do they come with the bung? I see alot of stuff in a picture on my phone but can't see a bung.
If it's the standard 18x1.5 pitch, I've used spark plug non foulers from the help section at Advance Auto. Stepper bit to drill in the hole then made a pass with the mig around it.
Before I had a welder, I JB welded one in.
Blair
1976ish CJ7
1981 Scrambler
1980 Cherokee Chief S
Old 02-19-2015, 08:37 PM
GWD6's Avatar
Yes, the kit does come with a bung.
'84 Grand Wagoneer
Old 02-19-2015, 10:57 PM
Achilles's Avatar
Achilles Achilles is offline
If not a welder you can google this. AEM 30-2355-250 - AEM No-Weld O2 Sensor Mount. http://www.jegs.com/p/AEM/AEM-No-Wel...34708/10002/-1 I purchased one but have not began my install yet.
YouTube: http://www.youtube.com/channel/UCmcfvYSDdeFJ-NHY1MA_9Iw
Old 02-20-2015, 02:03 PM
Any good exhaust shop can weld the bung in.
Cost will depend on the shop, but probably ~$25-$40 depending on their rates etc.
It can be done without removing the y-pipe.
I suggest bringing the o2 sensor with you, so they can ensure bung gets welded in the correct orientation/location.
They can be mistakenly welded in as to interfere with loosening/removing the y-pipe-manifold flange nuts. (ask me how I know)
Old 02-21-2015, 07:30 AM
BigOberg's Avatar
BigOberg BigOberg is offline
oh i wish i had a cool handle.......
Just make sure you keep your bunghole as tight as possible!
Old 02-21-2015, 11:37 AM
GWD6's Avatar
Thanks for the advice so far.
Stupid question, on which side of the engine does the bung go?
'84 Grand Wagoneer
Old 02-21-2015, 11:45 AM
Billygoat's Avatar
I believe the emissions legal kit you have uses a heated o2 sensor - so put it after the Y pipe to monitor both banks
Old 02-21-2015, 12:59 PM
Easiest spot is ~3-4" below driver's side manifold.
Not a lot of room anywhere else unless you drop the y-pipe.
Really no need to monitor both banks with TBI anyway.
Old 02-21-2015, 03:36 PM
Fleg Fleg is offline
I just welded mine in last night. Driver side but my Y pipe is different due to headers. I'd suggest going with a heated sensor if you start getting far away from the engine.
Old 02-21-2015, 10:26 PM
The O2 sensor should be as close to the manifold as possible. The sensor needs to reach 600* for the system to go into closed loop.
If you have headers then use a 3 wire o2 and put it in the collector of one header. The 3 wire has a heater built in and gets the sensor up to temp quicker.
At no time should you move the sensor further away from the engine nor is there a reason to monitor all cylinders by putting it past the Y pipe.
The extra distance will cause problems due to the delay in signal from the sensor to the engine exhaust output.
Bill USN-1
Hamilton Fuel Injection
Old 02-22-2015, 06:04 AM
GWD6's Avatar
Great thing to know!
Thanks!!
'84 Grand Wagoneer
Shock Install Advice chuckchili General FSJ Discussion 5 08-07-2008 08:24 PM
advice on parts after 4 inch lift install. interceptor General FSJ Tech 7 12-24-2007 09:21 AM
FSJ Daily Driver Advice (very long post) The PIG Smith General FSJ Discussion 17 09-07-2007 09:15 AM
Ignition Upgrade Install Question jeep_bags General FSJ Tech 1 07-20-2004 02:40 AM
Installing a Howell TBI fuel system on my 360 Arnold Fuel Injection 1 04-07-2003 01:49 PM
