Old 02-21-2013, 03:42 PM
Gambler68's Avatar
Rabble Rouser
Spring To-Do lists
Well..wheeling season is around the corner..what's everyone's lists?
Mine:
new ujoints in rear axle
complete fluid change (engine,TH400,QT)
16" rims and one elusive MT Km2 305...
battery for my nice new alternator to charge up.
new carb or at least something better than the cardboard gasket I made for it..the vaccum whooshing is neat to listen too but the mileage sucks.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 02-21-2013, 03:50 PM
Mr. Goatman's Avatar
Mr. Goatman Mr. Goatman is offline
Finish tie road
Install gas tank
Make new drive shafts
Install Tad Rack that I've had in storage for years
Install rear disk brakes
Install Hydroboost
New windshield
Make and install front and rear bumpers
Install TBI
All above and test mileage before leaving for Ouray
Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
Old 02-21-2013, 04:03 PM
Short list:
Pat Jeep on the butt while smiling.
Ride motorcycle more often.
Old 02-21-2013, 04:12 PM
jMedia's Avatar
jMedia jMedia is offline
Get a job
Hope it pays enough to have money for Jeep
Tow Jeep down to SD so I can work on it
Then the fun begins...
Joshua
Constantly changing, never done
Old 02-21-2013, 04:13 PM
localfiend's Avatar
localfiend localfiend is offline
Swap in SM465, NP205, HD44, & 14bolt
Axle Bearings
Hub Bearings
Rear Disc Brake Conversion
Hydroboost
Powersteering
Build Front & Rear Bumpers
Install PTO winch
Paint & Install Dash
Paint & Bedline Interior
Paint & Bedline Exterior
Install New windshield
Swap in Willy's Bed
Get new lift springs
Get new tires & wheels
Yeah..... I can surely do all that this spring.......
1964 Jeep Gladiator
Chevy 350
AX15
Dana 20 w/ PTO
Dana 44/53
Build: http://www.ifsja.org/forums/vb/showthread.php?t=171638
1966 Jeep Gladiator
Chevy 350
HD44, 14 Bolt
SM465
NP205
Build: http://www.ifsja.org/forums/vb/showthread.php?t=161426
Old 02-21-2013, 04:15 PM
nc wagoneer's Avatar
nc wagoneer nc wagoneer is offline
Sell four wheeler for jeep repairing money (in progress)
Trade "old blue" with Jake and Jackie for parts I need for the j20
Install starter I rebuilt (hoping to do it this weekend)
Replace clutch to make it driveable
See where I wanna go with it (farm truck, wheeling rig, etc...)
Hopefully rhinoline the floors, rockers, and along flares once I get the new parts
Install 5th wheel or make it a dump bed
Make winch bumper/install winch
Run a new exhaust possibly (have to hear this one this weekend and decide)
"BROWED AND PROUD"
Old 02-21-2013, 06:01 PM
dbabicky's Avatar
dbabicky dbabicky is offline
Swap TH400/Q-Trac out of 75 J-10 and install T-18/D20
Install new Smitty Built lowback seats into J-10 ------------ C/W direct bolt in, seating is now perfect.
Bed line J-10 bed and flares
Install TH400 and Q-Trac into 78 Chief
Work on Chief and try to have it good to go for my wife by Fall.
1975 J-10,360,TH400,QT,
1998 Wrangler,TJ,4.0L,5spd
2000 Chevy K3500,454 Auto
2009 GMC Canyon,3.7,Auto, 2.5" lift/leveling kit
all with a looney DAV behind the wheel.
"Old age and treachery will always overcome youth and skill"
Old 02-21-2013, 07:45 PM
Dr. Marneaus's Avatar
-Swap in the wood grain gauge cluster I have
-rebuild those D44's I'm picking up this weekend
-install those d44's i'm going to rebuild
-Swap my tires over to 6 lug rims
-drop my gas tank and have it sealed.
-drive it to Sequoia!
Originally Posted by FSJunkie
The Mag - The Wag
Old 02-21-2013, 07:51 PM
REDONE's Avatar
REDONE REDONE is offline
Well, the PLAN is to put 5,000 highway miles on the Money Badger between a move to Kentucky (2,500mi) and a trip to Ouray (1,250mi), then back to Kentucky (1,250mi, again) in June and July. My list is far too long to post up here, but after Ouray last summer, I can say for sure it's going to start with the seats!
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Dumpy's Avatar
Dumpy Dumpy is offline
Hope I actually get to wheel
Add a leafs in the front and old 3/4 ton springs in the rear until I can afford a lift (donations accepted )
Not break anything in between
Justin
'72 J2000 360 4bbl T18 D20
Old 02-21-2013, 07:55 PM
Wagn Man's Avatar
Wagn Man Wagn Man is offline
Install New Fuel Tank
Hopefully EFI Install
78 Chero NT..... nickname "Crash"
84 GW 401, Rhino Grille
03 Chevy Silverado 2500HD My DD/Tow Rig
Old 02-21-2013, 08:16 PM
hookedup50 hookedup50 is offline
After I get done with the GM project I plan to replace the the rocker panels and lower rear quarters then clean the garage so I can paint the wag properly.
Jennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
Old 02-21-2013, 08:22 PM
RWrightPhotog's Avatar
RWrightPhotog RWrightPhotog is offline
Finish stripping off fake wood.
Spray-bomb it
Recharge AC
Fix exhaust leaks
New u joints all around
New decent front shocks
Fix dash lights and courtesy lights
Keep it clean
Drive it
Bring Cherokee Chief project home and swap new motor into it
X2 ride motorcycle more.
Rob
1982 Jeep Wagoneer Limited 360
1979 Jeep Cherokee 4-Door 258
1979 Jeep Cherokee Chief 360
Old 02-21-2013, 08:37 PM
Suddendeath's Avatar
Suddendeath Suddendeath is offline
Clean up my exhaust welds
Fix the oil leaks
Fix the sloppy steering (rag joint?)
Work on the interior a bit
Drive it for more than 2-3 days at a time
1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
Old 02-21-2013, 09:01 PM
ScottsMojo's Avatar
ScottsMojo ScottsMojo is offline
x3 Ride more! :wheelie:
*Put DynaBeads in new tires (this weekend)
*Fix newly dysfunctional transmission (this weekend)
*Rebuild rear brake system, install new late model MC
*Install new windshield and gasket
*install new dash pad
*Pull all windows for tint
*Install new window wipes/seals
*Seal and paint interior roof
*Insulate interior
*Recover and install headliner
*Install new carpet kit
*Install AC system
*Replace rear window motor
*Install rebuilt QT w/MM part time kit
*Install new intake manifold
*Have '74 Cherokee bucket seats i have rebuilt? Maybe, not sure $$
That's the short list, parts already on hand.
Old 02-21-2013, 09:09 PM
Austin 4x4's Avatar
Austin 4x4 Austin 4x4 is offline
finish 5.3 4l60e np241 swap
put interior back together
put body back together
finish custom rear bumper
tires
shocks
fix bed
rino line bed, rocker pannels, and roof
instal HID lights behind grill
new windshield
and a hundred other little things to do in order to make it to ouray.
'73 J4000 4 door longbed http://www.ifsja.org/forums/vb/showthread.php?t=120147
'85 Wagoneer
YES i WILL be in ouray in 2013!
Old 02-21-2013, 09:58 PM
oh boy... one project at a time I guess...
The J20 will be going back on the road after:
brake overhaul
front axle ujoints and repack bearings
reseal intake and valve covers
work over fuel lines and filler for tank
finish replacing some sheet metal with better stuff
get wheels & tires back from Ryan
tag it
That means I also need to drag a trailer over to Durango and bring that Gladiator beast over here for storage.
Old 02-22-2013, 04:14 PM
Gambler68's Avatar
Rabble Rouser
brake overhaul
tag it
Yeah..I need to tear the steering box out and see what I broke..pretty sure I stripped the input shaft dry turning it..and that was with your dinky tires..pretty much proved 38's will be unmanagable. You're gana want new valve stems in those tires too..those aluminum caps you had on it seized up from sitting so long.
Old 02-22-2013, 05:18 PM
Too much to list
Old 02-23-2013, 07:24 AM
Finish dialing in fuel injection.
Wheel it.
Add a spring or two front lift. Subic Jeep Off-Road FSJ Tech 0 07-04-2008 07:23 PM
Need help with leaf spring mounting plate - 76 Cherokee Cherokee22 General FSJ Tech 20 04-03-2008 01:11 PM
69 Gladiator spring mount relocation Doesnuts General FSJ Tech 1 06-27-2006 05:24 AM
How to fix a stiff/bouncy J10 ride? OrlandoAlex General FSJ Tech 25 06-17-2006 08:51 AM
Article on Leaf Spring that may be interesting to some. Joker's '88 GW General FSJ Tech 2 10-28-2001 03:14 AM
