Old 03-02-2012, 10:01 AM
Wagn Man's Avatar
Wagn Man Wagn Man is offline
Question Throttle/Cruise cable bracket advice
So I order the recommended bracket Edelbrock 8031 that my Pro Flo 2 installation instructions suggest only to find the cut outs that the cable fit up in to are oversized for my application, 84 Grand Wagonnerr. Any of you guys have experiece with the Pro Flo 2 install, and what did you do for your cable hookup? Unsure at this point but I might just go with a home brew set up that uses pieces from the oem and the new Edl. bracket. Any advice is greatly appreciated. Please include pics if you have any.
78 Chero NT..... nickname "Crash"
84 GW 401, Rhino Grille
03 Chevy Silverado 2500HD My DD/Tow Rig
Old 03-03-2012, 05:13 PM
Wagn Man's Avatar
Figured out
Well after some toying around I have come to the conclusion that I will make a custon one with the factory bracket which doesn't appear to be too difficult, just some trimming and adding a stand to it.
On a side note does anyone have experience with Summit's return policy? As I understand it I won't be getting full price back, is this true?
Old 03-03-2012, 09:47 PM
FSJ Guy FSJ Guy is offline
I suspect that if you CALL them up and explain that the part didn't fit for your application, you can get a RMA # and send it back as long as the part is un-used.
But I've never done this. Once I got my Performer cam installed, I never wanted to send it back to them.
Ethan Brady
www.bigscaryjeep.com
Old 03-03-2012, 10:09 PM
Wagn Man's Avatar
Solid advice there
Old 03-05-2012, 03:58 PM
Wagn Man's Avatar
Kickdown
Well loose fitted my manifold to determine needed mods to factory throttler bracket to get it to line up right and found that my trans kickdown linkage will not line up due to the position of the intake runners. Anyone got any advice on this sudject? Currently on the phone with Edelbrock, will be talking to Summit next.
Old 03-06-2012, 09:11 AM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
Lokar makes a cable kickdown kit for the 727 http://www.summitracing.com/parts/LOK-KD-2727HT/
Also be careful when you set up your cable for the gas pedal. If you extend the cable too much the gas pedal will rise up. This can put the gas pedal even with the brake and lead to a condition where you press the brake and accidentally hit the gas.
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Blair Jeep Project III Tatsadasayago General FSJ Discussion 385 12-30-2014 08:03 PM
So what am I forgetting? 82 Widetrac Off-Road FSJ Tech 12 05-12-2010 07:31 AM
Negative battery cable question iroc86 General FSJ Tech 9 09-09-2009 03:43 AM
Need Speedo Cable Spec or where to buy blakeusa General FSJ Tech 1 10-07-2006 08:39 PM
alternator bracket? will a newer one fit my older 360? 72wag General FSJ Tech 0 07-22-2004 04:02 PM
