03-19-2013, 06:01 PM
I bet Mari likes those a lot. I do!
Me to. I can not believe Dr. did not want them when he picked up the
wheels and caps.
03-19-2013, 06:53 PM
Removed my factory fuel tank and skid plate. Which might I add if anyone is interested, it will be up for grabs. Will be posting in the for sale section soonish.
78 Chero NT..... nickname "Crash"
84 GW 401, Rhino Grille
03 Chevy Silverado 2500HD My DD/Tow Rig
03-19-2013, 07:13 PM
Shakes hands with danger
Wiped some graffiti off the rear bumper and removed three bumper stickers left by one of the previous owners. A small victory, but victory nonetheless.
03-19-2013, 07:25 PM
made the decision to park it for a while. time for some changes. axle seals started leaking. tc chain is loose. started removing the 400 and QT for a 700r4 and dana 300, 4.10s and hopefully zip locker. pan gasket, rear main seal, valve cover gaskets, and finish up the oba.
03-20-2013, 12:58 PM
Just received my cargo cover! Woohoo!
"There's just no use arguing with stupid people." -Thomas P. Elliott
03-20-2013, 06:28 PM
Changed my Tie-rod end that connects to the pitman arm on my 79. Replaced the oil in my rear Diff, and painted the cover to match the pickup. Tried to get the rear passenger side brake drum on the 63.
03-20-2013, 06:42 PM
Bought more parts and finished a cluster refurb.
03-20-2013, 07:49 PM
Took the column apart and tightened the 4 bolts that were loose.
Also replaced the power steering pump. Found out that the PS bracket was missing 2 of the 3 bolts. I was on the verge of complete failure.
WOW
04-01-2013, 11:24 PM
I took the seat out and to the uphostery shop. Broken springs to be fixed and smelly padding to be thrown away.
Started rewire for the rear end with parts from Napa.
1972 J 4000 (j4600)
304
3speed manual
4X4
Not much rust, but needs TLC
Been sitting for 10 years.
04-02-2013, 12:28 AM
Spring is here.
Ken's:
1966 Super Wagoneer
5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
04-02-2013, 07:15 AM
Always Broke
Went out to upper woodpecker. Scratched the front fender a little. Pictures to follow...
I might go run back road to crown king with some azvjc guys this weekend.
04-06-2013, 04:33 PM
Today I installed the Oil Pick-up tube and Canton Oil Pan Studs. They are shiny!
I also installed the fresh new cylinder heads. I used Fel-Pro gaskets. Not sure if they required the copper spray, but I did it anyway.
Now I have a LONG Block!
1988 Grand Wagoneer currently in pieces across the shop.
04-08-2013, 06:38 AM
Worked up the nerve to figure the fuel mileage in the wagoneer. I had been putting it off thinking that actually seeing how bad it was, would cause me to drive it less.
Turns out, it's not as bad as I though it was going to be. I tried not to be too easy on it (wanted real world average). I think I got a pretty good mix of highway, in town, and even working around the farm, and to my surprise, I'm getting 13mpg.
It's not as bad as I feared, and I think with a little more tuning (I suspect that the choke is sticking), I might be able to squeeze a little more out of it.
1987 Grand Wagoneer,
well worn, bone stock, with 120K miles.
added a snow plow, and looking for a lift.
04-08-2013, 06:42 AM
^ 13 is pretty darn good in my book.
I put in this little handy dandy gizmo:
1988 GW
04-08-2013, 08:08 AM
Dragged out the camper to give it an airing out and cleaning, its been in the family since it was bought new in 84. The plan is to repaint the camper to match the Jeep one day.
85 Waggon - SOA+Shackle Flip - OnBoardAir
04-08-2013, 09:43 AM
Did a side-view mirror swap and changed the mirror lens. Polished all the chrome on the mirror with a dremel. Got the new fuel filler neck installed. Changed and rewired the horn relay.
04-08-2013, 11:55 AM
Finished rear disk conversion and front bigger caliper conversion. All 4 tires on the ground again. Got new steel fuel line bent and brackets made to support them. Partially ran harness for TBI conversion.- List is getting shorter.
Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
04-08-2013, 02:16 PM
Sprayed all Engine Vacuumhoses with Silicone and the Electrical wires with WD40 (at the connections).
At Sunday i started the engine, and i could not belive > she is running a little bit smoother, more directly, stronger!
What does this say to me? I have to change all Vacuum lines, and maybe all Vacuum switches/Valves.
Markus!
Picture story:
04-08-2013, 03:08 PM
Slid down a loose pebbly slope on the beach at low tide and nearly sank the GW in the LI Sound. Luckily a bunch of other trucks were there and a big lifted JK Wrangler with a winch showed up, didn't even take much for the JK to winch the GW out, I just couldn't get enough traction on the loose surface, which looked like firm sand when I drove up on it. I am now wary of that terrain phenomenon. Very lucky I got out, high tide would have been up to my roof! Winch is now being purchased this week! Surprisingly, the only thing that got wet was the right rear wheel, I had to clean a bunch of sand out of my brake drum. Going to try and fit some wider tires soon.
'84 Grand Wagoneer 360/727/229, 32" General ST's and 36" Swampers, 3" lift, TFI/Mallory 6AL, CS 144, Taurus fan, custom bumper, and custom 'bodywork'. Soon to have 6" lift
'79 Cherokee S 360/T15/D20, rusting away while I figure out what to do with it
'91 Final Edition GW in Spinnaker Blue!
My FSJ pics
FSJ Grille Identification
04-08-2013, 03:14 PM
Really like this idea! Very cool
1990 Grand Wagoneer/Mary II/TFI/6"lift/33's-driver
1987 Grand Wagoneer/sold
