So unfortunately the Grand Wagoneer I am fixing up has the "factory" ASC installed sunroof, and I am having some issues regarding it. Because it was not common in these cars and there really aren't many out there with them at all nowadays, I can't really find much information on it.
The sunroof currently does not work. There is a pretty bad leak above the driver side from the pan catching the water that comes through. I have a hunch the drain hoses are plugged up and it is backing water up to that point. From what I can see, the gaskets aren't bad (no light coming through when shut); however, I'd really like to get the sunroof working so I can open it and check. Anyone know where the location for the sunroof fuse is? I have all the original parts/motors/switches for the sunroof hooked up but I am not even getting a sound out of the motor. Thanks, these things are a real big pain.
