Go Back   International Full Size Jeep Association > Tech Archives > Suspension and Steering
Thread Tools Display Modes
Old 08-08-2003, 07:53 AM
blt2krl's Avatar
blt2krl blt2krl is offline
Post
I'm going to be ordering my high steer arms from Poison Spider Customs here pretty soon and have some questions. First which is better for longevity and durability Hiem joints or Tie rod ends. What size tierod ends are the factory GM dana 60 setup versus our SJ's dana 44 setup. I thought I had read some were that the are the same 7/8 tierod setup. I'm leaning toward the tierod verson of the high steer arms because I like the ability to grease and mantian the tie rods. Any insight or opinions will be help full.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
DANA 60/14 BOLT 5.13'S AND DETROITS
39.5 IROKS C.B.I OFF ROAD TUBING GALORE
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 08-08-2003, 08:04 AM
dnixon dnixon is offline
Post
This is just second hand.. but from what I have heard Tie Rod ends have better longevity... and less likely to fail... But Heims are easier to set up.. its a give and take.. I am not sure on the size but i have only heard them called Big Chevy Tie Rod ends.. probably doesn't help.. good luck on your purchase...
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
Old 08-08-2003, 03:00 PM
KYJ10 KYJ10 is offline
Post
I am currently finishing up mine. I ran the single and double. The dana 44 drag link end fits perfect. I don't know if there are any diff in the tie rods. Sorry. But the drag link is a good fit.
Starting to miss the addiction!
Old 08-08-2003, 03:12 PM
JeepKahn JeepKahn is offline
Post
The rod end part #s are ES2010R & ES2010L, they came on the Dodge W ton up trucks, they are 7/8" by 18 thread, and are right and left threaded respectively... BTW, the part #'s are TRW part #'s, available at any TRW dealer...
\"Smoke\'m, They\'ll Stick\"<br /><br />Got Heat Problems???Want Free HP???<br />Check This Out!!!<br /><a href=\"http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412\" target=\"_blank\">http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412</a><br /><br />Jeremy Kahn Jeepkahn@yahoo.com<br />79 J10Honcho \"SickPuppy\"<br />360,Th400,D20,D44s@4.09,35x12.50s <br />Mobi-Arc on board welder<br /><br />Winston-Salem,NC<br /><br />!!!Will Weld for Gas!!!
Old 08-08-2003, 06:22 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
Post
in my understanding, hiems are better in that they last longer (if properly taken care of), and can offer more angular movement. and i believe that they are stronger then ball joints. although hiems are designed to use a mounting similar to spring hangers, (read, metal bracket on both sides of the hiem) and with steering that’s not the case. But I know many people that use hiems and have never had a problem.
my .02
If it aint broke, fix it 'till it is.
Old 08-09-2003, 02:38 AM
seadog seadog is offline
Post
In relation to this subject,does anyone know how long the "longer sleeve" will have to be on a widetrack with high steer?Parts Mike told me to measure and he will make and ship one but that puts me down on my ride for over a week.I will be using a 6 inch kit w/3" hanger spacers and blocks.So 9 all together.
Old 08-09-2003, 08:24 AM
Wagillac Wagillac is offline
Post
From what I have read Tie rod ends last longer because they are sealed from dirt and you can grease them.
Heims can be stronger then TREs when mounted in double-shear. They also can have a better misalignment angle when the corect spacers are used, but 1 ton TREs have a pretty good misalignment angle. There also can be a big difference in quality and durability between different Heims, also a lot of difference in $$$.
If you havent already done search on pirate and read the article in the tech dept, you should because there is some good info there if you weed throught the crap as usual. He went with heims and eventualy wished he had went with TREs for the cheapest vs durable.
http://www.pirate4x4.com/tech/billav...eringIndex.htm
Evan
1995 YJ 44/8.8 on 35"
1974 Wagillac NT D-44s Caddy 500 SOA (on hold)
Old 08-10-2003, 07:57 AM
River Beast River Beast is offline
Post
I would go with tie rod ends, Paul...
Todd
www.ttsfabworks.com
Thread Tools
