Old 06-22-2019, 06:32 PM
69project 69project is offline
Drive shaft trouble
My 69 wagon keeps throwing the driveshaft, I have the stock Dana 44 and Dana 20 in it. The wagon has the hell creek 4” lift. What u joints should I be running? What type of drive shaft should I be using? Could the yoke be damaged? Please include what setups you guys are running with similar rigs and lift
Old 06-22-2019, 08:41 PM
FMJBT FMJBT is offline
Throwing the driveshaft how? Sounds like you might need a longer driveshaft after the lift.
Old 06-22-2019, 09:34 PM
It’s breaking loose from the rear Dana 44 during normal street driving. I had it made by some company in Utah to accommodate the lift. Don’t know what’s happening, what’s the proper way to measure for added length?
Old 06-22-2019, 09:54 PM
Could be misaligned. Does it have a lot of vibration prior to breaking loose? The angle on the pinion should be more or less the same as the angle of the yoke coming out of the rear of the transfer case. If those angles are too far off it can cause a lot of vibration as the U joints on either end of the driveshaft spin out of phase with eachother.
Lots of good info here: https://www.therangerstation.com/tec...onangles.shtml
Old 06-24-2019, 04:12 AM
Ok. Thanks
Old 06-24-2019, 08:04 PM
Kaiserjeeps's Avatar
Got your email Matt. We need more information. What exactly is happening with the rear u-joint? Obviously it is coming apart, does it leave the bearing cup or cups in the axle yoke? Do you have U-bolts or straps for the yoke? Is it breaking the cross section? Does the driveline lay flat on a floor with it removed and on a flat surface, meaning do the bearing cup ears lay equally flat on the floor or bench or is one end clocked off or up from the opposite end?
When it comes apart and you get out, what do you see under there? In detail please.
The correct length when sitting with the rig on flat ground means the slip joint can be compressed and extended roughly the same amount when you take one end off and push and pull to extend and compress it. It should ride with room to move either direction, not extended with no extension to be had. Or compression for that matter.
Am I done yet?
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1953 Willy's wagon
1983 FJ60 wagon
Need help with front drive shaft fast! Dion General FSJ Tech 7 08-03-2011 09:02 PM
Front Drive Shaft - Please Help MadMax78 General FSJ Tech 8 08-02-2011 08:33 AM
U-Joint, Front Drive Shaft TBT General FSJ Tech 4 06-06-2011 10:41 PM
Dana 60 drive shaft trcooperone Off-Road FSJ Tech 7 06-26-2009 03:34 PM
Running without a Front Drive Shaft on Q-Trac? is it ok? Rocket Dog General FSJ Tech 2 05-23-2009 02:40 PM
