Old 06-20-2019, 06:08 PM
Anyone have the timing curve for a 71 401?
I don't see it on Tom Collins' site and Mr. Google is not helping me.
Old 06-20-2019, 09:55 PM
PlasticBoob's Avatar
All Makes Combined
Here's from '74, hope that helps.
http://apicalnetworks.zapto.org/host...mc_timing1.jpg
http://apicalnetworks.zapto.org/host...mc_timing2.jpg
Rob
Click for video
Old 06-20-2019, 10:01 PM
It does help some. In 71 401 had 9.5:1 compression (like mine) so I was going to start with that curve and go from there. By 74 401 was at 8.5:1.
Old 06-21-2019, 06:50 AM
Just remember you would need to plug it into something like excel and formulate the combined curves together("Hg vs. RPM)
I played with the factory curves way back when.
They didn't jive well with tbi MAP vs. RPM so I just modified the tbi tables.
1994 Caprice wagon
Old 06-21-2019, 08:07 AM
nograin's Avatar
nograin nograin is offline
If you can't find a '71 FSM, look for guys with a distributor tester and the tune up cards.
You can try Halifaxhops in Halifax Pa. He only rebuilds Chrysler distributors but may have and be willing to sell you the tune up cards your interested in.
A lot of unknown differences but something is better than nothing.
If you can figure out additional engine differences (such as cam and heads) if any that will help further.
Some general guidance.
Higher compression ratio produces better combustion development so less timing advance is needed.
Cams with high valve overlap have more exhaust dilution at idle and need more advance at idle.
Early emissions reduction efforts (late 60s -mid 70s?) focused on CO & HC at idle (and decel). To do this Chrysler purposely set the initial timing later than ideal. This put more heat into the cylinder walls and better insured burning up all HC. They also ran the idle leaner to reduce NOx.
AMC probably addressed emissions in a similar manner. I think this is why we see initial timing of 2.5* & 5* BTC in the '74 FSM PB shared. ( Also is certainly why idle speed is 700 rpm.) It will probably run just as well or better with a little more initial timing and the rest of the timing about the same.
Just for comparison, the later timing specs after introduction of catylitic converters have initial timing around 10* and 12* for the 2V equiped 360s.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 06-21-2019, 10:50 AM
Thank you, gentlemen. This is, spot-on, exactly the info I am looking for.
This is what was in my BIN when I started. I let out a huge gasp the first time I saw it. 46 degrees?!?! Doesn't a cylinder fire every 45 degrees? When I drove it the other night it was backfiring as I got on the freeway, I am assuming that is because the spark was jumping from my rotor to the next cylinder post....
I trimmed all the values over 36 down to 36. That was all the brain power I put into it for now. I drove it like this and it is MUCH better (especially when it's cold). I intend to add a knock sensor next month when I get back from my next trips so I can tune more finely. I also posted up the same question over on theamcforum.com.
Old 06-21-2019, 12:43 PM
what kind of operating circumstances are you getting backfiring?
map/rpm/etc.?
backfire out TB or out tailpipe?
a gm tbi distributor is designed for better operation vs. duraspark.
this is why proper phasing should be done.
If you look @ timing map very limited operation in cells with 46*
if you playback a datalog and let it populate table you'll see what I mean.
1994 Caprice wagon
Old 06-21-2019, 01:08 PM
I was merging onto the freeway, 3/4'ish throttle, higher RPM (maybe 3k?), and it popped 2 or 3 times but I didn't notice out the TBI or exhaust. I backed off the throttle, coasted off the freeway, and just drove around town for the rest of the time and had no other issues.
Today I drove it into work and had no issues. I hooked up my PCV this morning and that went fine, too.
I have some other issues to work on before I can tinker on my BIN more, anyway. My O2 sensor works great for a few minutes, then all the sudden starts going all over the place. I wonder if I torched it when I had it hooked up incorrectly. Look at this:
Old 06-21-2019, 01:09 PM
is it a carb or fuel injected? a little confused. I see now you have tbi. never mind!
Old 06-21-2019, 01:15 PM
Copy that. I have 73 401 heads and my cam card so I can compare them. I think my engine is close enough that the 71 card gets me in the ball park, then go from there.
Old 06-21-2019, 04:07 PM
o2 sensor will swing pretty good that is normal especially if fueling is off some.
1994 Caprice wagon
401 Timing with 9:1 compression pistons FSJ Guy General FSJ Tech 15 10-12-2010 02:25 PM
401 Timing Question rixcj General FSJ Tech 5 01-03-2008 05:09 PM
Timing Specs on 76 401 Eugene 1 General FSJ Tech 6 03-29-2006 09:48 AM
7 miles per gallon ?!?!?!?! jode General FSJ Tech 33 03-13-2004 02:32 AM
Stock timing curve specs for an 88 GW 1BDWAGN General FSJ Tech 3 10-12-2003 04:36 PM
