Old 06-16-2019, 12:07 PM
posulli88's Avatar
posulli88 posulli88 is offline
Coolent Overflow Tank Bolt Location
For some reason my front radiator support does not have the punch out for the bolt on the coolant over flow tank and I want to install the BJ's offroad Aluminum tank I have for it.
How would you guys go about making that punch out? I was thinking small dremel with a cut off wheel for the flat parts then a bunch of tiny holes to create the half circle shape. Then go back in a file everything smooth. Thoughts? Can anyone give me dimensions so I can locate this in the correct space?
My front Radiator support without the punch out:
What I am trying to recreate:
Old 06-16-2019, 01:17 PM
some never had the hole, cause they either did not have an overflow bottle or had a bag style on the inner fender panel, just cut it out.
Old 06-16-2019, 02:26 PM
posulli88's Avatar
Thanks Wiley. Man for some reason I thought these all had them. I just checked the TSM and it talks about the tube just dumping on thew road. Pretty funny. Might not install the tank now...
Old 06-16-2019, 08:39 PM
unless this is a super restoration, I would install one anyways.
Old 06-16-2019, 08:43 PM
These systems will pull/push coolant from/into overflow with heat/cool cycles.
A radiator that is overfilled will puke out excess.
Same with a proper overflow tank they will puke out if overfilled and suck overflow dry if underfilled.
Old 06-17-2019, 12:25 AM
Curly5759's Avatar
Curly5759 Curly5759 is offline
My77 Chero didn't have one. I bought a used tank from a member here, eyeballed the location of the tab and drilled a hole. Used a 90* aluminum bracket from the local Big box hardware store, attached bracket to sheet metal, attached tank to bracket. Not pretty but it works.
77 Cherokee S 360/TH400/QT
Old 06-17-2019, 10:44 PM
letank's Avatar
letank letank is offline
the 74 did not have a tank as Tony said, it would puke coolant in the summer at every stop... got a cheapo at the car parts store , it comes with it own bracket
a good example on dabay: Universal Coolant bottle Recovery reservoir Radiator overflow bottle small size
Michel
Old 06-21-2019, 01:21 PM
posulli88's Avatar
Thanks for the help everyone. I guess I just needed a little nudge to cut haha. Here is what I ended up with. think it looks good. just need to get a hose nipple to connect the hose.
Old 06-21-2019, 01:24 PM
perfect.
Gas tank vent hose location PaulD General FSJ Tech 3 11-24-2018 10:38 PM
Anyone install a BJs gas tank that fits in the spare tire location? rmorit01 General FSJ Tech 6 08-13-2013 07:28 AM
Installing 30 Gallon Blazer Tank ThisGuyUKnow General FSJ Tech 24 10-09-2010 08:32 PM
filler neck questions again mark General FSJ Tech 7 08-25-2003 12:39 PM
i think the 10 bolt is stronger scotty General FSJ Tech 16 01-08-2003 04:09 PM
