Old 05-24-2019, 02:20 PM
posulli88's Avatar
posulli88 posulli88 is offline
Help me diagnose this sound.
Had an exhaust leak and thought that was the sound I was hearing. Finally found and fixed the exhaust leak (I put the wrong style collector on my header ) That solved one issue but I am still hearing this sound.
Its a rhythmic clicking/ ticking sound you can hear at idle but you can hear it more on acceleration. I am hoping its just loud injectors in the Holly sniper system but I cannot tell. Hope this video is clear enough... Let me know your thoughts. Engine is freshly rebuild by Rick (SC/397) I have a little over 100 miles on it so I am not super familiar with the engine sounds. Oil pressure is great 60+ at cold idle 25+ at warm idle...
https://youtu.be/JP0ibnx2I5U
Old 05-24-2019, 08:03 PM
PlasticBoob's Avatar
All Makes Combined
What kind of cam is it running? Sounds kind of like one with aggressive closing ramp angles. My Comp Cam makes a similar racket after it's all up to temperature.
No big deal, but it drove me crazy for a couple of years measuring everything and getting second opinions from old school V8 mechanics to try to figure out what it was.
Not saying that's what yours is, but it sure sounds similar. Either that or maybe some loose preload, but I doubt SC/397 would let it get out the door with any issues.
Rob
Click for video
Old 05-24-2019, 08:13 PM
All Makes Combined
BTW, your engine would be much happier if you ditch the hot air intake.
If you click the video in my signature and then skip to 2 min 18 sec you can hear what a hot Comp Cams XE sounds like. That day my idle was set high and tuned for max vacuum (power AFR <14.7:1), which makes the valvetrain noises even more apparent.
Rob
Click for video
Old 05-24-2019, 08:17 PM
open elements amplify injectors, they will be pretty noisy with it.
honestly diagnosis of noises via videos is tough. sounds are never the same as what you are hearing in person.
Get a wooden dowel or loooong screwdriver/pry bar/etc.
One end to ear other end to suspected noise source.
It will reveal the culprit.
1994 Caprice wagon
Old 05-24-2019, 08:33 PM
All Makes Combined
Definitely hard to diagnose with video. x2 on the dowel/screwdriver/stethoscope.
Not trying to be disagreeable, but here's what injectors sound like. Go to 50 seconds and ignore the high pitched whine from the idle stop screw:
https://youtu.be/Ua0D4yFXK8k
Yeah my video has lousy audio, but his doesn't sound like injectors to me - sounds more metallic like the valvetrain. Injectors have more of a soft ticking without that ever-so-slight metallic "ringing/echo" if that makes any sense.
Rob
Click for video
Old 05-24-2019, 09:23 PM
posulli88's Avatar
It does have a comp cams 268H cam in it with forged pistons with the compression right under 10:1 and I think most would consider it a relatively aggressive cam. I have never owned an engine like this so I am just not sure what sounds are normal and what sounds are bad haha. Also don’t think Rick would let it out of his sight if preload was wrong. I have been going around with a long tube and there is definitely noise from the fuel injection and from under valve covers just not sure if it’s normal or not haha.
I will try the dowel trick. I guess I could remove valve covers and have a look at the preload again and just make sure everything looks normal.
What air intake do you guys suggest? My engine did not have an air cleaner on at all when I got it so I bought the K&N
Old 05-24-2019, 09:42 PM
All Makes Combined
Surprise surprise, haha.
268H is Xtreme Energy, right? Personally I'd say you're fine and it's totally normal for that type of cam. Keep an eye on it and see if it gets any worse, but otherwise enjoy! Hot rod engines make hot rod sounds.
It's disconcerting at first but you get used to it after a while, though I have to say that yours sounds a little more "loose" (for lack of a better word) than mine - but that might be because you have a bigger cam than my 256. They sure slam those valves down hard, but man do they make a nice powerband.
I was at a car show once and heard a Chevy making the exact same type of noise and thought "that sure sounds like my Jeep!" - surprisingly when I talked to the guy he said he had a Comp Cam in it.
Rob
Click for video
Old 05-24-2019, 09:48 PM
All Makes Combined
Air intakes are tricky. I had to put one together using a bunch of parts, here's the thread:
http://www.ifsja.org/forums/vb/showthread.php?t=145690
I should have gone with 3" instead of the overkill 4" and would recommend the same for anyone else. Not sure how much torque I'm losing with that huge of an intake tube but the Jeep is still plenty strong.
Rob
Click for video
Old 05-25-2019, 06:22 AM
posulli88's Avatar
The Comp Cams 268H is the High Energy level not Extreme. Its 110 degree lobe seperation 268 duration (218 at .05" lift) Valve lift is .456 and lobe lift is .268.
Here are its specs: http://www.compcams.com/Company/CC/c...x?csid=15&sb=0
Thanks for the Cold Air post. Super helpful! Maybe a project for me down the line.
Old 05-25-2019, 10:17 PM
I have a fresh rebuild as well and am running the 260H, 9.1:1 compression. Around 100 miles right now, and I have a similar noise but seems to be getting quieter with mileage. Going to change the oil soon and pull off the valve covers to doublecheck preload, measure lift just in case I wiped the cam.
So... following this thread hard.
From the threads I've seen SC/397 runs a few gallons of gas through the motor and it's broken in when you get it - so am hoping it's a normal noise!
I know it's hard when you have a unique motor and don't know what it should sound like. Every noise becomes the loudest noise!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 05-26-2019, 06:39 AM
fsj454 fsj454 is offline
Long time member
oil
Hi and nice job . I would like to now what kind of oil you are running . Was motor up to temp for video or cold . I just put a AMC rebuilt engine together and it does not sound like that . What I would do first is change oil to Amsoil Z rod oil 10 30 . It sounds like you have wrong oil in motor
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 05-26-2019, 12:56 PM
posulli88's Avatar
I am running Comp Cams 10W 30 break in Oil and then a bottle of a Zinc Additive per Ricks instructions. I have only probably put 100 miles on the engine and Rick Suggested doing the first oil change before 1000 miles and go to the oil I will run regularly from then on. His oil suggestion is 15w40 Rotella with a zinc additive. I will reach out to Rick to get his thoughts as well. Like I said before Rick is a pro so I am sure the preload is correct.
The engine was up to temp in the video (155 degrees) and has around 25 psi at hot idle 60 when cold... The Noise is definitely more noticeable when the engine is warm. I don't really hear it until the engine warms up.
Old 05-26-2019, 04:24 PM
Long time member
Check Oil
I think oil is contaminated .To much junk in oil assembly lube .cam lube .bearing lube and so on .I always beak in engines for 2 or 3 hours and drain oil . And put fresh break in oil in . I never use that zinc additive .Rang a stang had big problems when he broke his motor in with all that crap stuck in the oil filter . I use Amsoil break in oil 1 case . and 2 good oil filters to properly break in new rebuilt. I think that junk is in oil filter and staving top end of oil .Just my 2 cents oil is cheep insurance
Old 05-26-2019, 04:47 PM
posulli88's Avatar
When Rick Builds the engines he breaks them in and changes the oil and filter and then runs them more before sending out the engine so he is checking two filters and oil changes. So the oil and filter I have in it now is the 3rd round in about 100 miles worth of running if that makes sense (two changes for Rick, 1 for me when I received the engine) So I don't think it would be contamination. Im thinking I change to the Rotella Rick suggest and check the filter when I pull it for contamination. Hopefully that solves it.
With 60 psi warm idle and 25 cold of oil pressure I would think oil would be getting to the top end.
Old 05-26-2019, 05:27 PM
Long time member
cam kit
I purchase a comp cam kit extreme but it was to large for me . So I got a rv MT 1 cam . But when I looked and inspected lifters that cam with comp cams kit they were not up to my standards plungers were sticky and did not move up and down smooth so. I purchased old stock Federal Mogul lifters made in USA and compared to comp cam lifters and they where not sticky and worked as they should . Just cause it is new does not mean it is good. So I have a new set of comp cam extreme energy lifters if you need .
Old 05-27-2019, 05:50 AM
SC/397's Avatar
SC/397 SC/397 is offline
I just listened to the video a few times and it does sound like valve train to me. I also went through all of the pictures and vid of the build and there is nothing obvious there that I can see that is wrong. I did spend extra time to get the lifter pre-load right but I would have set them up on the conservative side. The engine was nicely broke in and didn't sound like that before so, I want to carefully think about this and check some things before throwing new push rods in it.
http://www.ifsja.org/forums/vb/showt...=183735&page=4
Not that there is any ties but, did it sound like it does now when you had exhaust manifolds on it?
Do you still happen to have your old oil filters laying around so that we can cut them apart?
Old 05-27-2019, 06:12 AM
posulli88's Avatar
I really did not run it that much before I did the headers and new exhaust but it was long enough ago I can't fully remember if it had that tick before the headers. Ive been thinking this is an exhaust issue for a while but I have fixed all my exhaust leaks so its not that.
I did the hose trick to try and find the sound. Its definitely not the fuel injectors, those are making there own sounds but quieter and a completly different tone and pace. So I agree with you guys it sounds like top end.
I have not changed the oil since when I got the engine from you Rick. But I have only driven it less that 100 miles (close but I would say 75-95 miles, I have been doing a lot of work on the jeep haha). When I did get the engine back from you and before my first run I put on a new Baldwin B9 Filter and 10W30 Comp Cams Break in oil with A Zinc Additive. So that is what is in there now.
Should I change the oil and open up the filter? Want me to take off the valve covers as well, to have a look?
Old 05-27-2019, 02:23 PM
posulli88's Avatar
Ok here is the update. I just drained the oil, strained it all through a paint strainer to look for contamination and cut open the oil filter (with tin snips) to look at the filter condition.
_There was no contamination in the oil.
_There was no contamination in the paper filter.
_There was some very small metal pieces in the bottom of the metal oil filter housing (underneath the paper filter) see images. It does look like a couple of the pieces are blue so maybe those are just paint but there is definitely some tiny metal bits in the bottom of the filter.
What are the thoughts on this? Could this be from the filter or me cutting it with tin snips? Or would something like this be bearings...
Here are some photos (the one with the finger is me sticking my finger in the bottom of the metal filter housing):
Old 05-27-2019, 04:40 PM
Do the pieces stick to a magnet?
1994 Caprice wagon
Old 05-27-2019, 04:56 PM
posulli88's Avatar
Yes, but I honestly can't tell if its because of the oil viscosity helping it stick to the magnet or because its actually metallic. There is some red color in the "debris" which is the color of the oil filter housing. Looking into the bottom of the oil filter housing the specks definitely looks metallic. But there is not enough of them that its piling up on the magnet if that makes since. I know thats not very helpful haha.
Wagoneer 401 - weird sound during jumpstart from 0mph the_only_real_db General FSJ Tech 13 06-07-2017 11:50 AM
Hi Pitched Whirring Sound NEW SOUND TO ME ajminla General FSJ Tech 10 01-19-2013 08:13 AM
Diagnose engine problems using starter Perfex General FSJ Tech 0 04-14-2010 03:51 AM
Strange Humming sound shadowfax101 General FSJ Tech 6 05-08-2006 11:09 AM
Why is my Jeep making a sound like a cow bell? FSJDreamin General FSJ Tech 15 10-30-2004 01:55 AM
