My tailgate glass has always been a bit tempermental, and last year the key-operated switch stopped working. The other day, the interior switch that usually works stopped working with the glass down. Normally a good open and close of the tailgate solves this problem, but not this time.
I proceeded to take off the shag panel and access panel to see what I could see, which is not much since the glass is stuck down. What I did see was a black wire with a connector on the end that is just dangling from behind the glass. Does this need to go somewhere? My safety switch is already bypassed, so I was wondering if maybe this wire needs to be connected somewhere to ground the thing, but from what I read it is all grounded through the dash switch.
I also read about how to get the glass out by removing the clips (somehow), but if I can get the thing up without having to break these as I would most likely do, it would be sweet.
I guess my next step is to remove the tailgate switch and make sure things are at least making contact there?
If anyone has or knows of a good wiring diagram that shows that area I would kill my own mother for a link...
-Coach
-Coach
