I was replacing some of the rotted lines off my charcoal canister and noticed a filter coming off the carb line. Looks almost identical to the fuel filter. Is there a part number for this or a replacement? It's an 88' wag
Charcoal canister?
It is NOT a filter. It is a vapor separator. No replacement part available. Basically, it has a metered air bleed inside it and if you try to replace it with a fuel filter, you will be running too lean...'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
