Hello again!
I want to reassemble the EGR system stripped apart by the previous owner but it would seem that I'm missing some components. Pictures would really be helpful from those of you with similar year vehicles that have the EGR system intact.
I have a 1982 Wagoneer Limited with the 360. I need pictures of the entire EGR control system from EGR valve to all of its vacuum controls. I'm especially interested in the "EGR TVS", "VSD Valve", and "Vacuum Advance and EGR Daul CTO Valve".
According to Alldata's vacuum diagram, there is a single vacuum line from the EGr valve that connects to a tee. One leg of the tee connects to the "VSD Valve", the other goes to the "EGR TVS". A vacuum line then goes from the "EGR TVS" to the "Vacuum Advance and EGR Dual CTO Valve".
I really need help identifying these components so I can replace them and get my EGR system running properly. I'll try to upload an image of the vacuum diagram I'm referring to.
Diagram
Diagram with needed components circled
Any help you all can offer will be appreciated!
Diagram
