Old 01-12-2010, 10:41 AM
Dagz_07's Avatar
Dagz_07 Dagz_07 is offline
Front Disc Brake Conversion 68 J 3000
Im ready to get rid of my old drum brakes on the front and replace with discs. Not looking to spend a pile of money, and Im looking for a bolt right up setup. Anyone care to share their ideas?
Jordan Dagenais
1968 J3000 9 inch lift, built big block buick, 35"x 13.5 Toyo Mud Terrains mounted on 15x10 +35mm offset Eagle alloys
Old 01-12-2010, 12:32 PM
crazydog's Avatar
crazydog crazydog is offline
BJ's has a kit and if you search, you will find a thread with a parts list, if you want to gather the parts yourself.
1967 J3500 - Making plans
Old 01-12-2010, 10:40 PM
Dagz_07's Avatar
Cool, thanks man! Searched and found this article out of JP magazine, lists all the goodies I need!
Jordan Dagenais
Old 01-12-2010, 10:57 PM
glady8r's Avatar
glady8r glady8r is offline
Banned
I only paid 6 for my dana 60 big brake swap already installed on the dana 60 I bought!!!
reffering to bjs kit
Old 01-12-2010, 11:13 PM
orangebike's Avatar
orangebike orangebike is offline
can you post the link to the jp mag artical?
81 chief-straight six auto soa and 3 inch body lift 3/4 ton running gear...37 boggers...ready for 39s....Wheeler
74 401 t18 lifted 6" on 33s for now..soon to be firewood/tow rig
73 j4000 -360-th400 d20 on 33s....now the farm rig
Couple parts jeeps
66 chevelle ss-396
66 chevelle clone 396
Stuff for free.....is worth saving up for
Old 01-13-2010, 12:49 AM
Cappicaper's Avatar
Cappicaper Cappicaper is offline
I think this might be the article he is talking about.
78 Wagoneer, 401, Turbo400, QT, Posi Rear, 4" lift, 33X10.5 BFG
69 Gladiator, Buick 350, T18, 14B, 44HD, Cross-over HIgh Steer, Hydroboost, 6" Lift, QR78 Buckshots
63 CJ5, 302 Ford
Owner Buckstop Truckware, Inc
www.buckstop.biz
Old 01-13-2010, 09:06 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Link didn't show up.
http://jp.automotive.com/26367/154-0...ion/index.html
My rotors are 2.8" high and they touch the caliper bracket. AZ part #5109 is listed as 56mm or 2.2" high. Pricey. Tried Ford and Dodge rotors and spindles, outer shafts would not line up U-joint with kingpin. Currently looking at newer Dodge rotors to fit over flange, not behind it.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 01-13-2010, 09:52 AM
Cappicaper's Avatar
You need to click on the word "this" to go directly to the link.
63 CJ5, 302 Ford
www.buckstop.biz
Old 01-13-2010, 09:54 PM
lkmarsh's Avatar
Oops, didn't see the blue, new glasses should arrive next week.
Lyle
Old 01-14-2010, 12:09 AM
Cappicaper's Avatar
Found a D44 out of a 77 Chevy 1/2T tonight for $25! On my way to a little disc action
63 CJ5, 302 Ford
www.buckstop.biz
Old 01-14-2010, 07:45 AM
Gambler68's Avatar
Rabble Rouser
are you going to just swap the outers, or the whole D44?
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 01-14-2010, 12:15 PM
Cappicaper's Avatar
No, I think I will just go with the outers and keep the original axle and bolt pattern.
63 CJ5, 302 Ford
www.buckstop.biz
Old 01-20-2010, 03:23 AM
Buick Boy's Avatar
Buick Boy Buick Boy is offline
Master??
The article doesn't mention a front disc master cylinder upgrade. I'm considering using a '74-'80 I think J-truck piece for my '69 upgrade, requiring converting to a pedal mounted brake switch. Does this sound right???
--Dan
69 J3600 Dauntless 350 T-18 D20 4.09 D53-D44 utility boxes on bedsides 'FARM TRUCK'
69 J2600 Dauntless 350 T400 D20 4.09 Powr-Lok D53-D44 'PROJECT'
68 J3600 Dauntless 350 T-18 D20 4.09 Powr-Lok D53, D44 'PARTS'
69 J3600 Dauntless 350 T400 D20 4.09 D53-D44 'PARTS'
70 Buick Skylark convert 350-4
70 Buick GS455 Stage 1 hardtop project
Old 01-20-2010, 05:30 AM
I got the Willys....
I would think a master from a later model (mid 70's) FSJ with disc brakes would work fine for your app.
Do you have manual or power brakes right now?
Also, you don't need to use a pedal mounted switch. You can plumb in a hydraulic switch in the brake lines and re-use your original plug.
1971 Gladiator
Old 01-20-2010, 08:03 AM
Gambler68's Avatar
Rabble Rouser
That switch you see on your newer brake pedal isnt a brake switch, its the kick down for the TH400. common mistake.
Old 01-20-2010, 08:21 AM
Tonka J200's Avatar
Isn't the kick down switch on the gas pedal, and the one on the brake pedal is the stoplight switch?
-Frank
'63 J200 2WD
'63 J100 Panel Delivery
Old 01-20-2010, 09:05 AM
lkmarsh's Avatar
Hydraulic switch in the brake line was a bad idea. It's just another leak waiting to happen. Brake pedal should have either a brake light switch or cruise control release. It's easy to rig a brake light switch to the pedal, I used a GM part.
Lyle
Old 01-20-2010, 12:31 PM
Buick Boy's Avatar
That's the master I'll use. I have power brakes. Sounds like I'll need to trim my brake rod by 1-1/8"
I'm away from my Jeeps right now but it seems to me that hyd. switch on the bottom of the master can't be added to the disc master. does that switch control the brake lights AND system idiot light???
Lyle, I agree on the ease of replacing it with a brake pedal switch from a Skylark, if the warning light gets its signal from a prop valve like GM....
Thanks for your help guys....
--Dan
Old 01-20-2010, 02:20 PM
Josh D's Avatar
Josh D Josh D is offline
I used a M/C from a '76 CJ with non-power disc/drum. It bolted right up to my '71.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 01-20-2010, 03:15 PM
Buick Boy's Avatar
That's good to know-- I need to stay with PB so my wife can use it to plow the driveway when I'm at work....
--Dan
