Old 06-12-2006, 07:21 PM
bowtieman55 bowtieman55 is offline
Question A/C to non A/C (heat only)
I'm sure some FSJs came from the factory WITHOUT A/C...I was thinking of taking all the A/C stuff off of the Heap (compressor, lines, firewall box, etc.), but I want to have heat/defrost for winter wheeling. What all would I need to keep and does anybody have a A/C delete firewall box they would like to part with?
Old 06-12-2006, 07:42 PM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
From what I understand, the AC system is a complete stand alone system. The heater is the same with or without AC...
Pete
Isuzu 6BD1, NV4500, NP241
Old 06-12-2006, 07:49 PM
never_2_high never_2_high is offline
just take all the stuff for the a/c off and your done all you need is time i did it and relocated my alternator to where the a/c compreser was works out great for water crosings no mor sawgy alternator
Old 06-12-2006, 08:11 PM
88GWSteve's Avatar
88GWSteve 88GWSteve is offline
Does anyone know how much hp gain and weight loss for the FSJ?
Steven
1988 Grand Wagoneer, mostly stock, Holley 2bbl carb, and new Sony stereo
"My lug nuts take more torque than your Honda makes"
Way
All
Great
Old-timers
Never
Ever
Earn
Riches
Old 06-12-2006, 08:15 PM
That's a great idea never_2_high. I'll have to remember that one.
I'd like to get rid of the big A/C box on the passenger side firewall...what I was asking (and maybe I'm confused with the stand alone A/C setup) is whether or not FSJs used a non-A/C firewall box sorta like GM used.
Old 06-12-2006, 08:24 PM
oldyellowwagoneer oldyellowwagoneer is offline
The box on the firewall is the heater only. a/c unit is contained in the under dash unit. Dennis
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
Old 06-12-2006, 08:26 PM
JeepBountyHunter's Avatar
GrimJeeperReaper
Earl,
What you have on the firewall is just the heater fan cage, and next to it is the heater core box. These items have nothing to do with your a/c. The Compressor lines run through your firewall underneath those components and into the evaporator in the a/c housing underneath the dash. This a/c housing also has the fan cage for the a/c...
Heater and A/C are totally different systems on FSJ's...unlike GM's..
2005 Mustang Convertible...meh....
Too many hobbies! $$$
Old 06-12-2006, 08:30 PM
THANKS YALL!!! I finally have it figured out...LOL
Ok...well dang, I'm still stuck with the big black box...maybe I'll just try to get the A/C working... ONE DAY ANYWAY. The Heap has alot to be done BEFORE I even start to be concerned with that. Thanks again everybody for ALL the input!
Old 06-12-2006, 08:34 PM
jsinajeep's Avatar
I took all of my A/C and Heater box out. What I did for heat was, I went to part store and got a heater core for a Ford Van and built a box with a fan behind it and mounted it on the tranny hump. Made a cover for the front to control the air flow for the defroster. You can buy almost the same type unit in some 4x mag. I have picture some where if you want to see it.
Old 06-12-2006, 08:41 PM
That would be interesting to see
Old 06-12-2006, 09:21 PM
another way I've seen it done was to get rid of the heater box and plug the hole with sheetmetal then run your heater hoses to the a/c evaporator. There is plenty of heat and you also have the fans and vents still. I'd get an electronic water shutoff and use the a/c switch to power it. Dennis
Old 06-12-2006, 09:48 PM
The PIG Smith's Avatar
King Browless
When I was in the Army, we used a heater from a 5 ton truck to put in Jeeps, Deuce an a Half and and just about anything and everything.
They are self contained, just run power (24volts) and engine heated water to them and they work great.
Get really hot!
Duct work is optional.
Here is a Internet pic of an example of one in use:
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 06-12-2006, 09:55 PM
King Browless
Here is a source for them:
Army Surplus Warehouse: Jeep Heater $69.95
Text from the ad:
Jeep Heaters have heavy duty heater core.
Simple to hook up, your two heater hoses fit over 1/2" pipes and then hook up 1 wire to switch.
These are 24 volt but we have sold hundreds of these and found that they work just fine on 12 volt.
Perfect for snow plows tractor cabs or jeeps.
New. Government Issue.
$69.95
Bryan Smith
Old 06-13-2006, 10:13 AM
GrimJeeperReaper
Awesome Bryan, thanks! I have a use for that.
Old 06-13-2006, 10:20 AM
AMSting AMSting is offline
Does anyone know the dimensions on this? My wife complains about the heater in her Wrangler, and this looks like a great upgrade. I wonder if it would fit under the hood? If I run the heated air through the existing vent, I think I should still be able to direct it with the normal vents.
Chris
Alcohol doesn't solve any problems, but then again, neither does milk.
1980 Cherokee Chief W/T, "Big Dog" 360-2v, 727, NP-219, 3.31, PW, PDL, AC, white w/ blue Western int.
Old 06-13-2006, 02:26 PM
4LoTJ's Avatar
4LoTJ 4LoTJ is offline
I've got an 81 Cherokee and I'd sure like to get rid of my heater box too. I've heard they are smaller/less obtrusive on some model years. Anyone have any info or pics?
-Jen
1981 Cherokee, 4" lift, 33" BFG tires, Edelbrock carb & Offenhauser intake, custom 3" exhaust, headers, Flowmaster
A list of things I'm looking for:
Cargo floor and tailgate trim pieces
Old 06-13-2006, 09:45 PM
jsinajeep's Avatar
Now, I have the picture of the heater I build. But need help on how to put them in the thread so you can see them. I have already down size them.
