Old 04-22-2010, 06:07 PM
Seemer Seemer is offline
Rear Main Seal....anything else besides this?
I'm doing the oil pan gasket and RMS this weekend. Aside from the nice write-up below for RMS, is there anything else to be aware of / special tricks etc. to note? Tools that may help? Thanks a lot.
Rear Main Seal Replacement
Contributed By: Joe Schaefer
NOTE: This is from the 1973 Jeep Technical Service Manual J-73-1001 and applies to all 258/304/360 and 401 engines.
The rear main bearing crankshaft seal consists of a two piece neoprene single lip seal to effectively seal the rear of the crankshaft. Correct installation of the seal will insure leak free engine operation (Fig 36).
Removal and Installation
  1. Drain the engine oil and remove the oil pan.
  2. Remove the oil pan front and rear neoprene oil seals.
  3. Remove the oil pan side gaskets.
  4. Thoroughly clean the gasket surfaces of the oil pan and engine block.
  5. Remove all sludge and dirt from the oil pan sump.
  6. Remove the rear main bearing cap.
  7. Remove and discard the lower seal. IMPORTANT: To ensure leak free operation, the upper and lower seal halves must be replaced in pairs.
  8. Clean the main bearing cap thoroughly to remove all sealer.
  9. Loosen all remaining main bearing caps.
  10. With a brass drift and hammer, tap the upper seal until sufficient seal is protruding to permit pulling the seal out completely.
  11. Wipe the seal surface of the crankshaft clean; then oil lightly.
  12. Coat the block contacting surface at the upper seal with soap, and the lip of the seal with engine oil.
  13. Install the upper seal into the engine block. CAUTION: The lip of the seal must face to the front of the engine.
  14. Coat both sides of the lower seal end tabs with "Permatex" No. 2 or equivalent, being careful not to apply sealer to the lip of the seal.
  15. Coat the outer curved surface of the lower seal with soap and the lip of the seal with engine oil.
  16. Install the seal into the cap recess and seat it firmly.
  17. Place "Permatex" No. 2, or equivalent, on both chamfered edges of the rear main bearing cap.
  18. Install the rear main bearing cap and inserts.
  19. Tighten all main bearing cap screws to the specified torque.
  20. Install oil pan using new gaskets and seals.
  21. Tighten the drain plug securely.
  22. Use new engine oil to fill the crankcase to the specified level.
Old 04-22-2010, 06:15 PM
Jack up the front end and support the frame rails on both sides so the front axle can hang down. Gives ya more room to get the pan out and back in.
Old 04-22-2010, 06:20 PM
Wagonforever's Avatar
Wagonforever Wagonforever is offline
Does this actually work on an old high milage engine? I would think there'd probably be a groove chewed into the crank from the original seal and thus would cause the new seal to leak.
There are those that have and those that will.
1986 Grand Wagoneer, BONE STOCK just the way I like em!
The Aviation Forum
Fred 08
Old 04-22-2010, 06:33 PM
The Colonel's Avatar
I just pulled my engine apart with 109K, no grove on the crank.
Old 04-22-2010, 07:10 PM
Blinkinlights's Avatar
Blinkinlights Blinkinlights is offline
How about some pics:
Oil pan prior to cleaning
Rear main cap still on
Rear main cap off
Rear Main cap on the bench
Rear main seal being tapped out
The chamfered edge mentioned in the directions that nobody knew where it was
The new seal
87 Grand Wagoneer 360/727/NP208
BJ's Front and Rear Dozer Bumpers
35x14.5x15 Boggers on 15x10's
Mile Marker H10500 Hydraulic Winch
http://photobucket.com/albums/y174/bANGr/
It's all fun and games until someone breaks a woodie.
Old 04-22-2010, 07:12 PM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
Hope it doesn't leak afterwards...
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 04-22-2010, 07:18 PM
Leak
CJ - I went through 2.5 quarts during my 300 + mile drive home. It could only get better than that.
Nice pics Greg!! Thanks
Old 04-23-2010, 05:25 PM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
Don't be too sure of that! Not questioning your ability, only the inevitable appearance of that Murphy guy.
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 04-24-2010, 09:30 AM
710 Burner's Avatar
No. 14 is very important. Do NOT glob it on there. Just a skim-coat.
Mark B. Jones
Old 04-24-2010, 03:10 PM
Y Pipe?
Having a tough time getting the pan out with just the starter removed. Will it wiggle out or do I have to remove the Y pipe too?
Old 04-24-2010, 03:21 PM
newtojeeps's Avatar
I have had to losen the y pipe to get mine out.
Old 04-24-2010, 03:42 PM
710 Burner's Avatar
Sorry, forgot to mention that....some have had to take the h-pipe loose. I for one.
Mark B. Jones
Old 04-24-2010, 03:51 PM
OK
OK- well the bolts are nothing but little rusted nubs so this should be fun. Just sprayed em with some PB but I'll probably have the get the hack saw out.
Old 04-24-2010, 04:29 PM
If you have air tools, try an impact. Sometime the "jolt" is enough to free them loose.
Old 04-24-2010, 11:23 PM
shackwrrr's Avatar
or shear them clean off at the manifold
Mine cam right loose with an impact but I snapped on off with a 3/8ths ratchet in one hand
Jeepless
In to Turbo crap now
Old 04-24-2010, 11:42 PM
getlost4x4's Avatar
getlost4x4 getlost4x4 is offline
that main bearing is in really good shape.
have fun with the oil pan. hope it seals. it took me three tries to get it right.
www.getlost4x4.com
78' Jeep Wagoneer (Tank), Built 360, 330 Miles, QT
360 V8 (fresh rebuild), Summit Racing 8600 cam, GM TBI Conversion (in progress), 31" tires no lift, 2.5" exhaust system,dual batteries, T-Max 9000 lbs winch, many plans empty pockets
Old 04-25-2010, 01:41 PM
Note
Note to self....always start by removing Y pipe first, if you can't remove Y pipe don't go any further. Well, I guess I kind of did this backwards with the starter out, the pan free but hung up etc. So far, no luck getting the bolts loose. Of course I have just the basic home hack tools....no air tools, torch etc.
More PB Blaster? bang the bolts harder? What gives?
Old 04-25-2010, 02:31 PM
Go buy a small hand torch and heat them up.
Old 04-25-2010, 04:33 PM
FSJ Guy FSJ Guy is offline
And when you re-install the y-pipe, put a good coating of anti-seize on there. I do it every time the y pipe comes off. Even if there's still some old anti-seize on it. You can't have enough of the stuff on those bolts!
Ethan Brady
www.bigscaryjeep.com
Rear Main Seal Woes... cajun_lad General FSJ Tech 12 11-17-2012 10:49 PM
rear main seal x6xdemonx6x General FSJ Tech 6 03-23-2010 06:12 PM
Rear main seal? hard to replace? 72wag General FSJ Tech 12 08-20-2004 03:27 AM
REAR MAIN SEAL...What have I done wrong? Dogs-in-the-back General FSJ Tech 7 04-27-2003 06:55 AM
Rear Main Seal Help Needed Mike10000 General FSJ Tech 23 10-07-2002 11:01 AM
