Where does the line from the top of the egr go to?
And Do I need to vacuum metal line that runs from the catalytic converter to the driver side (it has a check valve on it and it sits next to the check valve from the air pipes). It connects with the same hoses as the air pipe check valve.
Make sense. My 89 had it but the 87 was removed. So where it connects to the cat on the 87 it was cut and welded shut.
[ December 01, 2003, 05:17 PM: Message edited by: klank ]
