Howell $1300
FITECH $995
Hamilton $1400
I'm an intermediate driveway mechanic. Never done this before but willing to try.
I'm leaning towards the Fitech because of price and seems a lot less clutter and it seems you don't have to mess with the distributor. I've never timed a vehicle before but somewhat have the idea.
Upon reading and scouring for quite some time, Some say you need to mess with the distributor anyways and it seems there 100 mods that everyone argues about in lingo I don't really understand. I don't want to drill a hole in my distributor cap to make sure everything lines up right that I welded together and wired shut after I tap and die a screw that I ground down so it would clear the spinner mechanism. This just sounds like something I'd screw up really bad.
Howell and Hamiltons have a distributor with the kit already setup I suppose? Fitech claims will work with my stock one.
I'm also confused about if I need to buy a fuel sending upgrade. I'd like to upgrade but not sure what to buy here.
They all 3 seem to have a new fuel pump with kit but all offer other alternatives.
Fitech has some fuel command center can thing. I can't figure out what to do with it they say it's a fuel pump but it looks huge. Where would this thing mount? Seems a good thing to have? Does it make noise? They sell another inline fuel pump separately too and a linkage for $29. Would I need all these? That would put it over $1600.
Gas tank and fuel sending unit- I just put in a newly engineered fuel sending unit piece of crap from TGW that I had to mess with 19+ times to finally get it to work right. Would I keep all that the same or do I need a new gas tank with an in tank fuel pump so it's quieter on the end of my sending unit? And a lot of talk about changing my fuel lines to bigger ones rated for hi pressure.
Also should buy the the Doug Thorlel headers they sell on BJs and have them installed first? Does Doug Thorley come with a pre installed bunghole? I was thinking to order them and have a muffler shop install them and put in a o2 bunghole so I could just screw in the o2 sensor, or should I attempt this install myself and drive down and have them install the bunghole. Seems easy enough to do but seems easy enough to not get a good gasket seal.
I'm trying to plan this thing out so that I can order everything at once and only have to do it once and not be missing anything, and get it right.Never done something like this so I could use some advice here on a list because I'm not quite sure all I'll need. I'll just go through their instructions step by step so hope they have good ones.
Thanks
Stock 87 GW.
FITECH $995
Hamilton $1400
Thanks
Stock 87 GW.
