Thanks everybody for the help. It nearly took me all day monkeying around
mocking things up this way or that way. I was nervous about welding that bracket in the wrong spot. Got frustrated and walked the dog. Was able to come up with a different plan. Got back into the garage and it seemed to work.
Funny how it took me sooooo long to figure it out. Anyway I attached the spring to the new front shackle then used the "indicator' knob of the new leaf, lined that up with the female knob taker (wait what am I describing here)
on the bottom of the axle. Stuck my jack under both and raised it up into position with the new bracket already mounted. I think I'm pretty darn close.
The picture is a little dark but you can see the old revit and the spring eye are
at a nice angle like the original.
Welding was tricky. My Miller 135 will not Mig weld 1/4 steel. So I needed to switch to fluxcore. The problem I realized right away was that the bracket is 1/4 steel and the frame is only 16g steel. Had to sit on the bracket and whip the puddle up onto the frame. Its not pretty but its solid and I will probably try to brace is some more. With weight the front shackle angle seems good.
Onto the drivers side. Thanks again
IMG_0579 by , on Flickr
IMG_0580 by Colin McArthur, on Flickr
