Need some with the vacuum system on my jeep. I have been going through the vacuum lines and replacing them one at a time trying to eliminate any leaks. The PO's have taken out the emissions system, the air pump and I am sure many other things I haven't realized yet. It does have a new Edelbrock Carb 1406 on it. I have a TSM for the 360 and for the carb. I have been looking them over, but there is so much missing I am not sure if it is hooked up right.
Here is my problem. On the front side of the carb there are three ports. The center one is the PCV port, no problem.
The one on the right a 3/16" manifold vacuum ( Distributor vacuum advance port for non-emissions controlled engines) This one is hooked directly to the vacuum advance.
The left side one is a 3/16" timed vacuum ( Distributor vacuum advance port for emissions controlled engines) This one is capped off.
I also have nothing hooked to the EGR valve or the EGR CTO switch.
Also the manifold vacuum? ( top front of engine near oil fill) has two ports on it and only one is connected to the brake booster and the other is open.
Ok, so finally the questions. Is the carb hooked up correctly to the ports? Should I reconnect the EGR valve? What does the other port on the manifold
vacuum go to.
Thanks for your help.
vacuum go to.
