Old 12-09-2008, 01:28 AM
need new exhaust (note I have TBI)
Greetings everyone, Time has come for me to get a new exhaust setup. I know that when you have a mc 2100 everyone suggest that you get a single exhaust with 2.5 inch pipes. Well I have adapted the engine to Throttle body injection so with that in mind what exhaust would you guys recommend for that? Also I might need a new muffler and cat converter. Any suggestions? Since I am getting the exhaust done I might as well get the cat and muffler changed (slightly higher flow) To let the engine breathe some. Any suggestions on cat and muffler and pipe size (Keep in mind that it is Throttle body injected and it has an 02 sensor in the stream.) (Not an exhaust guy so dont know if that would have an affect on things.
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Old 12-09-2008, 07:42 AM
crazydog's Avatar
crazydog crazydog is offline
http://www.ifsja.org/forums/vb/showthread.php?t=93905
1967 J3500 - Making plans
