06-05-2019, 04:08 PM
Headliner restoration
1979 Wagoneer
06-05-2019, 04:10 PM
So there was some warpage. I gave the cardboard liners a good soak with the garden hose and gathered all my heavy stuff to flatten it. I hope this works.
That heavy roll of duck tape should do the trick!
1979 Wagoneer
06-05-2019, 07:51 PM
Shoulda put down a piece of plywood or at least boards down on the headliner before the weight... distribute the weight evenly.
06-06-2019, 08:18 AM
I finished the panels at midnight last night. Easy project. I didn't use the typical headliner material because I feared it would show the many imperfections in the old cardboard material.
I am very pleased with my amateur results!
Here's a side by side. The one on the below right is the one I removed from my wag. I cannot believe I tolerated it for the past 11 years. There was no rear panel.
1979 Wagoneer
06-06-2019, 08:26 AM
Looks good. Wuhja use?
Sic friatur crustulum
06-06-2019, 08:58 AM
Lots of lightweight polyester carpet (made from recycled drinking bottles) and 3M spray adhesive.
1979 Wagoneer
06-06-2019, 11:38 AM
nice work
looks great
good idea, using different material to hide bumps, etc.
it feels good to do a project yourself.
still jealous over your wagoneer
the front end, the perfectly aged red exterior.....nice.
dave in NC
06-06-2019, 12:47 PM
Nice job. I
06-06-2019, 04:28 PM
..And, it smells like rootbeer!
:  98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
06-06-2019, 07:57 PM
Vanilla Coke!
1979 Wagoneer
06-06-2019, 10:49 PM
This is such a satisfying project. Came out looking good. It'll look even better in the Jeep.
*Remember to carefully cut out the little holes for the lights before install.* Would hate to have the job half done, than realize there's nowhere to install the over head lighting...
What imperfections would there be? A little warpage, or did you fear that the material wouldn't stick properly (leaving new saggy spots)? My rear board is a little warped/sagged, but its not really that noticeable to others, or even myself if I'm not looking for it. If I'm looking for it, then I can see it. It droop's a bit from where the light is on each side. Remind's me of a set of boobs when a girl is bent over!
1990 Grand Wagoneer-"The Wagon"
...not too rusty anymore
Lots of patina  and my daily driver.
The others
Too many to list here anymore...
I got a problem with collecting cars...
06-07-2019, 12:08 PM
I won't be reinstalling the overhead lights. The front chrome light assembly as well as the rear light and switch are long gone. That's why I filled and covered the holes in my "new" headliners. Instead, I will be installing LED strips along either side of the headliner. I'll post pics after they are installed.
1979 Wagoneer
06-07-2019, 11:43 PM
Amazing!
How flat did your headliner come out? Mine is super warped, too and I figured I was relegated to buying new/$$$$$$ one but if yours came out nice and flat, maybe I'll try that, too!
( Cherokee Build Thread)
06-08-2019, 12:34 AM
The thing is, the light supports the board.
06-08-2019, 04:02 AM
Amazing!
They are much flatter than before, but don't over do it. The headliners are only cardboard and they will delaminate/disintegrate. The 88 degree day and hot driveway really sped up the drying process. Without it, I suspect they could have just laid there and turned to mush.
1979 Wagoneer
06-08-2019, 04:08 AM
You are correct and I realized this yesterday. Problem is, i never had the overhead lights. I will have to come up with an alternative for headliner support. I have ideas....
1979 Wagoneer
06-08-2019, 05:06 AM
My new "Benchmade" tool. Saying its "sharp" is an understatement.
1979 Wagoneer
06-08-2019, 08:33 AM
daft,
does that mean you got cut using it ?,.....I hope not.
dave in NC
06-08-2019, 08:53 AM
No, I haven't cut myself with it.......yet. It's dang razor sharp though!
1979 Wagoneer
06-09-2019, 10:03 PM
1979 Wagoneer
Thread Tools |
Display Modes |
