Old 02-12-2010, 03:12 AM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
Question GW has a hard time starting
So now that I have my waggy on the road, it has begun to have a hard time starting. It can be pumped twice when it is cold, it would turn over and run for a second, but that is it. After that, the carb is flooded out, and I have to use starting fluid to make it start and run. what could be the problem?
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 02-12-2010, 08:10 AM
710 Burner's Avatar
Are you sure its flooded. If it were flooded, I would think giving it more fuel in the form of ether would make it worse. Could your fuel pump be losing its prime? too much choke or not enough? are there any other symtoms...anything, smokes, chugs, misses, ticks, coughs, sputters?
Mark B. Jones
