Old 10-10-2019, 09:05 PM
aerocorey's Avatar
aerocorey aerocorey is offline
Carb Bowl Vent Solenoid
Thinking bout using this in place of the carb bowl vent solenoid:
https://www.usplastic.com/catalog/it...x?itemid=85394
I'm thinking install it backwards so the direction of flow runs toward the carb, not toward the canister. With a 1 PSI cracking pressure, I think it would allow fumes to escape as desired when desired, but it would seat and effectively close the vent with the engine running.
No emissions inspections in my area. Just like trying to make things work.
Thoughts?
Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
90 GW parts rig "Velma"
77 J10 parts rig "NoMo" (as in "no more Jeeps, Corey!")
94 YJ "Coop"
Past
88 GW "Hercules" (had to sell in '08, curious who has it now)
83 Wag parts rig "Shaggy" (used to build Herc, then scrapped)
73 J4000 (had to sell due to PCS in '07)
75 Cherokee "Jerry Lee" (sold in '13 because I'm an idiot)
74 Cherokee "Dino" (used to build Jerry Lee, then scrapped)
Old 10-10-2019, 10:35 PM
twmattox twmattox is offline
It needs to vent freely when not running and be closed when running. From what I have read, if you can't find a replacement, it is just best to plug the vent to the charcoal canister. The carburetor will continue to vent inside the air cleaner; it just won't be captured by the charcoal canister.
'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
'88 Grand Wagoneer (SJ) / 360 / TF727 / NP229 / DANA 44 (2.73)
'05 Wrangler Unlimited (LJ) / 4.0L / NSG 370 / NV231 / DANA 30-44 (3.73)
'15 Wrangler Unlimited (JKU) / 3.6L / 42 RLE / NV 241 / DANA 30-44 (3.73)
Old 10-11-2019, 08:19 AM
aerocorey's Avatar
Do you think the vent pressure would exceed 1 PSI?
Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
94 YJ "Coop"
Past
Old 10-11-2019, 10:27 AM
No. The bowl vents are always open to the air horn (top area of the carburetor, inside the air cleaner). When running, the solenoid valve is closed and the bowl vents are active. When the engine is off, the cold air door comes down to block the air cleaner snorkel, and the solenoid valve opens. The canister is now a less restrictive path for the vapors to vent, but no way is the air cleaner door going to seal enough to hold 1 psi of vapor pressure.
I think TW's advice is good - just block it and leave it in place if you need to retain factory appearance. If you worry, you could block open the cold air slightly and let the vapors from the bowl vents freely vent through the cold air intake.
Old 10-11-2019, 12:01 PM
acct21's Avatar
acct21 acct21 is offline
Still available on eBay -- $20-40. Just search "bowl vent solenoid" and several Motorcraft pieces come up.
Old 10-11-2019, 12:09 PM
aerocorey's Avatar
I bought a few of them. Unfortunately they're all the wrong thing. They're advterised as "vent" solenoids, but they're actually"purge" solenoids... normally closed, energized open. The one on the bowl needs to be normally open, energized closed.
I found one that should work. Napa carries a vent solenoid and wiring pigtail for a mid-2000s Chevy truck whick is normally open and energized closed. Picking it up tonight.
Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
94 YJ "Coop"
Past
Old 10-11-2019, 03:08 PM
chubbinius's Avatar
chubbinius chubbinius is online now
Cool! If it works, please share the part number and Napa name/number! Good luck.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 10-11-2019, 09:26 PM
GWNashville's Avatar
Intersted in that number myself. Thanks
Richard
GWNashville
1989 Grand Wagoneer 360 c.i.
727 Transmission
Sniper EFI Hyperspark
Old 10-11-2019, 09:31 PM
aerocorey's Avatar
It works. I'm gross right now...will post update and part numbers soon...
Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
94 YJ "Coop"
Past
Old 10-12-2019, 02:36 PM
aerocorey's Avatar
Here it is:
https://www.napaonline.com/en/p/NDP6001628
It's large, but it works. The fittings are the same OD as the stock vent hose. I made coupling sleeves out of some larger diameter hose and snugged it all up with hose clamps. That's just what I had laying around. I'm sure it could be adapted better with a bit of glue and some plastic vacuum connectors.
The wiring pigtail is EC848. These are late '90s through I think 2010 Chevy/GMC parts, so I imagine they'll remain available for the foreseeable future.
Corey
Current
87 GW "Big Bear"
76 J20 project "Ox"
94 YJ "Coop"
Past
Old 03-29-2020, 12:49 PM
Jeep Doctor
Nice find!
Thanks for the part #s.
Rerouting the 2150 Carb Bowl Line? wjamesbass General FSJ Tech 15 12-22-2015 09:30 PM
MC2150 carb bowl is dry after sitting overnight Blake General FSJ Discussion 27 11-30-2011 03:58 PM
Bowl Vent wires silvercert General FSJ Discussion 4 10-06-2011 04:44 AM
2100 Carb Solenoid chethro General FSJ Tech 1 01-02-2011 07:51 PM
carb bowl vent question 8689gwagons General FSJ Tech 2 10-17-2008 02:35 PM
