Hi!
I'm sick and tired of patching the same dang leak on the original steel tank in my 73. The stupid vent tube at the front of the tank has a broken weld and it always leaks a few weeks after I fix it. tried putty, JB weld, more putty, more jb weld, cant get it to stay sealed very long.
I'm also sick and tired of having to crawl under there and get covered with gas every time i have to drain 3 gallons out of the tank to stop the leak and patch it.
If you cant tell, I'm fed up!
I've got a tank/skid out of a 1980. the plastic tank that mounts to the skid, and the skid mounts to the truck.
What is different about this tank and what will I need to do? Obviously i'm going to have to drill a bunch of holes in my frame rail to bolt up to, thats fine, thats what a corded drill and step bits are for!
Are the other mounting points the same? (i have one at the front, and one on the side by the drive shaft, then one at the back, i think).
I believe this is when they swicthced over the the fuel level/pickup being all 1 part, correct? Does this mean it's going to be the reverse polarity sending unit so my fuel gauge will no longer work? If so, how do I solve this problem?
Lastly, these tanks have a return line, correct? So i can just get a 2 pronged fuel filter and run a line back to the tank, thus helping to keep my fuel cool!
