Old 09-22-2017, 03:03 PM
Dana 20 full of ATF
My 1978 J10 project is about 3/4 done and now I'm puking ATF out my transfer case on the floor.
I have a TH400 converted to accept the Dana 20 with factory parts. I assume there must be a seal that is either bad or missing between the adapter and the transfer case ? since my TSM doesn't cover this combination I don't have anything to go off of.
Old 09-22-2017, 04:18 PM
Can you verify the ATF level in your trans is going down? Does D20 take ATF or gear oil? I guess what I am getting at is: are you sure where that ATF is coming from?
2011 Nissan Pathfinder Silver Edition 4x4
2009 Mazdaspeed3 Grand Touring
1999 VW Cabrio (my daugther's to drive, mine to maintain)
1979 Jeep Cherokee Chief Wide Track, 401, bone stock
Old 09-22-2017, 04:33 PM
I got the Willys....
There are two seals in your transmission to transfer case adapter. One on each side of a large bearing. Sounds like both are bad.
Edit. Seals are both on one side of the bearing.
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1968 Gladiator J3000 3406Z 160" wheel base DRW 350/T18
Old 09-22-2017, 06:10 PM
Yes, my transmission is low enough it won't hardly move.
I pulled the case and adapter and one of the seals is shot, the other looks okay. I'll replace both of course.
The next thing is I've seen talk on the web about an O ring on a chevy that must be in place or it will leak. on the input? I don't know where.
I would assume a chevy with a TH 400 and a Dana 20 would be basically the same set up. but I can't confirm any of this. I wish I had a TSM from the early 70's.
mattmopar440's Avatar
well if you didnt put ATF in it its comming from the TH400 the TH400 has no output seal so the input seal on the Dana 20 is bad
91' Grand Wagoneer
401/727/229, Currently:Down for Body Work
77' Wagoneer 401 Parts rig
80's J10 258/T-5/208
89' Jeep GrandWagoneer
New Project
Inferior Chevy
Old 09-22-2017, 06:22 PM
There are 2 seals in the adapter to hold in the ATF, the Dana 20 is wide open. so those seals I understand.
I still don't know about the O ring or where it goes or if there is one. it looks as if ATF could work it's way between the gear splines on the TH 400 output into the Dana 20. somewhere here is where I think the O ring come into play.
Old 09-22-2017, 10:37 PM
bufurd's Avatar
bufurd bufurd is offline
The o ring is on the output shaft in a groove to keep atf from going through the splines. I've "siliconed" up the splines when I put t case on in past and never had an issue
Current fleet
Abner-73 He started it all in 1979 (plow truck now)
Bufurd-69 Fixed up to take Abners place as DD
Delta-70 Built for fun, 455 Olds, T-18, D-20, 4:10 gears
Humpty-74 J-20 4BT, NV4500, 30+MPG
07 JK Wife bought new...
13 Grand Cherokee Trail Hawk, wifes new ride
Old 09-23-2017, 08:00 AM
mokurt mokurt is offline
My old '67 was leaking the same.
I replaced the seals in the adaptor,replaced adjacent gaskets/orings and siliconed the splines.
1967 J2000
1985 CJ7
Old 09-23-2017, 08:07 AM
There is a groove on the output shaft with no O ring on it. no doubt this is the problem. I'll put one on as well as silicone. since I have it apart I'll put new seals in the adapter.
hopefully this will help someone in the future, I searched hard and there seems to be very little helpful information on this issue .
If Jeep could make a full size pickup what direction would they take? kmass5050 General FSJ Discussion 22 03-14-2009 10:54 AM
Changing a Dana 44 bolt pattern Fox Off-Road FSJ Tech 18 09-27-2006 05:54 AM
Anyone Full Float a waggie rear end? Dan Stewart General FSJ Tech 8 08-16-2006 09:55 PM
Full Floating D44 Rear aatcman General FSJ Tech 9 07-08-2006 10:24 AM
Dana 44? always thought so. dweezle General FSJ Tech 2 12-22-2000 03:11 PM
