Linkage bushings
  • streetglide
    • Feb 06, 2009
    • 217
    Linkage bushings
    Are these white plastic shift linkage bushings still available somewhere?
    84 J20..Down to frame resto at the moment. http://www.ifsja.org/forums/vb/showthread.php?t=98908
    69 Dodge Coronet(Super-wanna-Bee)
    77 Dodge M880
  • FSJ Guy
    • Mar 20, 2005
    • 10061
    Transmission shop?
    Help! section of the parts store?
    Ethan Brady
    www.bigscaryjeep.com
    • streetglide
      • Feb 06, 2009
      • 217
      I'll do a little checking around tomorrow locally like you suggested. This one is in decent shape yet but the other is looking worse. I can come up with a thick piece of plastic and drill the appropriate size hole through it if necessary, since its basically just a supporting pivot point.
      77 Dodge M880
      • The Colonel
        360 AMC
        • Feb 21, 2010
        • 2842
        That bushing is jeep part number: J535 2589.
        I believe it's still available from the dealers.
        The small bushings aren't but can be found in the "HELP!" section of the parts stores.
        • joe
          • Apr 28, 2000
          • 22392
          last time I needed some NAPA had an assortment you could pick from but you had to know which ones you wanted.
          • Daddio
            • Dec 13, 2008
            • 277
            '88 Grand Wagoneer, towing package, 360 .030, Holley Street Dominator intake, Holley Projection, rv cam, double roller timing chain, HEI, CS144, oil pump mid plate, Thorley Headers, BJ's 3" exhaust, and more...
            http://www.youtube.com/watch?v=xWWCj...layer_embedded
            • streetglide
              • Feb 06, 2009
              • 217
              Thanks for all the help guys.....I need to get some up to date pics on this project of mine....
              Got the new bushings from the local Jeep dealer. Part # J535 2589 has changed to # 5207 8134
              now everything is nice and snug with no slop. Little brass bushing's pivot freely and should last indefinitely!
              77 Dodge M880
              • fulsizjeep
                • Aug 21, 2002
                • 22496
                Bump to let y'all know this part # 5207 8134 is still available at Jeep dealers. I ordered one today for a T400 at the local dealer for $10.50. The part is used for T400 (1 each) and 727 (2 each) It also comes in a Crown kit.
                BJs Offroad has the kit for 727 for $16.50:
                Based on the picture, it just shows one however.
                • Bob Barry
                  Jeep Doctor
                  • Apr 09, 2000
                  • 8335
                  There is indeed only one in the new kit; you can replace the other with a 1"x3/8"x3/8" nylon spacer (I got a pack of two made by "Hillman" from my Lowes).
                  The BJ's kit has bushings that can be used for the shift-rod ends, but I needed to modify them to work; I detail that in the video series on rebuilding my shift linkage:
                  1987 J-20
                  Video projects for my J-20 on Youtube
                  • fulsizjeep
                    • Aug 21, 2002
                    • 22496
                    https://youtu.be/y6S1vmVdL18
                    Nice work there Dr. Bob! Thank you.
