Old 03-06-2009, 08:59 PM
beloth's Avatar
beloth beloth is offline
Unhappy stalls in drive at idle...runs fine under load
this started tuesday evening...in the parking lot at home...idle went a little up/down in speed...then STALL....put in nuetral and started right up...parked it...drive to work today, when accelerating it is fine...when deacelarting it is fine...no stumble and stalling like when EGR valve goes bad,
stuff that has been done...EGR valve replaced 2.5 years ago...
fuel pump replaced 14 months ago....
carb rebuilt about 3 years ago....
fuel filter on it is about 3 years old....
when it is idling when you first start it...IE COLD and CHOKE ON..it is fine..once it starts to warm up then the above begins..starts right back up...choke opens when it is warmed up...
i have gotten in almost 4 accidents trying to get this JEEP home today....freaking fun stuff....NOT!!!!!!
So until i can get this issue resolved...i am driving my GMC truck...
powervalve is not leaking...
i have had fuel filters clog and then the vehicle just stops running and won't restart...i am going to swap that this up coming week...if i place the vehicle in nuetral at a light it did not stall...but something in drive seems to not make it like life....
need recommendations...it is not spark related...since it starts and runs...ditto for fuel....
1966 wag "JENNY" w/1973 drivetrain
330K miles w/360 V8 2bbl (HEI installed ), flowmaster muffler
TH400 /Dana 20 transfer case D30 /D44 w/ 3.73's LT235/75/R15 AT tires. lift shackles in frt. 2 in lft; w/ TAD's Dozer bumpers! Cost $700 -now total cost=?
Old 03-06-2009, 09:10 PM
FSJ Guy FSJ Guy is offline
Could your idle speed be set too low?
Ethan Brady
www.bigscaryjeep.com
Old 03-06-2009, 09:12 PM
beloth's Avatar
could possibly be...been fine for several years until tuesday...you adjust that with that selinoid that is on the side of the carb right? this is a MC2100 carb...
Old 03-06-2009, 09:38 PM
stonehengeheels's Avatar
stonehengeheels stonehengeheels is offline
Adjustment
I had to adjust the solenoid first then the the idle speed screw.
Old 03-06-2009, 10:32 PM
silvercert silvercert is offline
OK how is the solenoid adjusted? And when setting the idle do you guys do it in park or drive. Because mine sounds like its gonna take off in park but cuts off as soon as you put it in drive.
