Old 08-06-2008, 07:39 PM
chuckchili's Avatar
chuckchili chuckchili is offline
Shock Install Advice
I was wondering what everybody's preference is when installing shocks. I just got Rancho 9000's and I am putting them in my 1966 truck. My question is...can up or can down? What are the pro's and con's of each way? Thanks everyone.
Old 08-06-2008, 07:43 PM
FSJ Guy FSJ Guy is offline
IIRC, the adjuster goes DOWN, as in towards the bottom. I know, easier to knock off, but that's the way I've run them.
Ethan Brady
www.bigscaryjeep.com
Old 08-07-2008, 04:42 PM
Greenfire's Avatar
Greenfire Greenfire is offline
Yep, I have those shocks. Barrel on bottom, adjuster faces back.
1984 J10
Old 08-07-2008, 05:37 PM
misfittom138's Avatar
misfittom138 misfittom138 is offline
X2
81 Wagoneer 360/727/208, lockrite rear/welded front,4.10s, 7"SOA/shackle flip,3" body,OBA,37" Iroks,chopped,caged,highsteer,hydro assist....
Old 08-07-2008, 06:08 PM
Herk's Avatar
Herk Herk is offline
Also, unless the shock speciffically says it's omnidirectional it is best mounted with the main body down. Some shocks just plain dont work well upside down. RS5000's for instance.
Old 08-07-2008, 08:24 PM
ne715 ne715 is offline
If you had an older set of RS9's you can mount them anyway you like as the units are "full of oil" and experiance no cavitation if mounted upside down (clicker up), the newer style is a triple tube design and are not full of oil and will cavitate. Mount them clicker down.
Alan
