Old 09-23-2007, 11:53 AM
84Gw360's Avatar
84Gw360 84Gw360 is offline
Rear axle shaft length??
I have a bent pass. side axle shaft on my wag. I have found another wag at a u pull it, but it's pass. side is also bent. My luck. My question is can I take the drivers side axle shaft and use it on the pass. side?? It's an Model 20, are they equal length? or if not would it work as a bandaid?
Carl
http://www.cardomain.com/ride/2556190
84 GW 360,727,229 ... 3" RC lift,sway bar disco's, BFG At31's, TFI
