Old 12-14-2010, 07:08 PM
TatankaJ20 TatankaJ20 is offline
Noob!
wiper arms
I was curious about swapping out late J20 wiper with the type you can position out from glass for cleaning, overnight ice build-up etc.?
Old 12-14-2010, 07:14 PM
letank's Avatar
letank letank is offline
Wood block under the arm, it brings good luck before driving on ice..... when you remove it.
Sorry I could not resist.
I can prop mine up, then flip the wiper blade around.
Michel
Old 12-15-2010, 06:24 AM
FSJs never had this option. Good luck finding arms that will fit and stand up like that.
Old 12-15-2010, 06:32 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
The wiper arms on your J20 should have a small tab that you can pull out to prop the wipers off of the windshield. Look at the hinge area by the base of the wiper arm.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 12-15-2010, 07:34 AM
ok, never seen this tab - wow
Windshield wiper chatter... at my wit's end iroc86 General FSJ Tech 14 02-15-2012 03:08 PM
Wiper Motor pin outs JpX General FSJ Tech 4 06-26-2009 07:29 PM
stainless or black wiper arms baybilly General FSJ Discussion 0 03-27-2008 07:06 PM
Windshield Wiper Arms Blinkinlights General FSJ Tech 3 05-14-2006 03:38 PM
Windsheild Wiper Arms bchesley General FSJ Tech 5 06-19-2001 07:28 AM
