Hey fellas,
This weekend, I hope to fix an exhaust leak on my new-to-me '88 Grand Wag. The PO installed a Holley 4-brl carb in place of the original. So, the air injection tubes are no longer connected. He attempted to weld the air injection tubes closed, but I'm pretty sure that's where my leak is. Now, for the question. Since the air injector tubes aren't connected, could I just remove them and fill the banjo bolt holes in the manifolds with regular bolts? If so, what size and thread bolts do I need? Do I need gaskets on the bolts or would steel washers do the trick? On an unrelated note, what tranny did this wag have from the factory? TH400 or 727? Thanks.
John
John
