Old 01-24-2007, 08:03 PM
malodin's Avatar
malodin malodin is offline
my experiences with a 14bolt swap into a cheif
MY 14bff swap experiences.
First off a little back ground
1977 cheif with a th400/d300 swapped in and a new crossmember made.
1977 chevy k20 4x4 with hd44 and 14ff(parts)
ok so i was able to swap in the 14ff with relative ease. i have 3" blocks which might have made it easier, We started by bolting one end of the 14 down tight to the leaf(the pass side) then we used a combination of a come along a tow strap and grunt to pull the leafs together long enough to get the u-bolts into the plate, this took some beating on to get it but not that much we had to use some c-clamp vise grips to squeeze the u bolts after warping them out to fit over the larger size axle tube, yes i reused the ubolts that were in the jeep, as they were less than a year old and made longer for the 3" blocks, im pretty sure we used the chevy spring plates(but will have to check)
once it was bolted in we loosened both sides of the spring's just barely and bounced the jeep up and down then tightened everything down, this brought the springs almost square(they tilt in by no more than half inch)
then we bounced on it again, to see if there was any binding, there was none(though i havnt taken it on the road yet) the brakes were almost a strait swap with hoses, if you dont have a lift you could probably get away with using the stock rubber fsj line, or the chevy one for that matter. they have the same fittings the chevy one is longer.
I have a stainless steel brake line from skyjacker i used, i had to get a different T fitting for it in doing this i ended up having to use one of the d44 steel lines to move the location of the T to a better location.
For the drive line i am using the stock fsj, i dont know what it would be with a q/t but with the d300 the stock fsj drive line goes right into the d300 ubolt's and for the 14ff side i just got a conversion joint from napa (napa number 240-0358 or spicer 369 i think.) i plan on doing
a disk brake swap as well, but for the time being this will get it up and moving.
All in all it was relatively easy swap.
sorry no pictures of the swap, but i can post some pictures of it in and ready to go this weekend.
Old 01-24-2007, 09:21 PM
8379qtj10 8379qtj10 is offline
That's all I got
Tyler Johnson
No Jeep
It's been real...it's been fun...but it ain't been real fun.
Old 01-24-2007, 09:35 PM
malodin's Avatar
sorry to dissapoint you , but thats all it took to swap it in and i was in a hurry to get it done so i forgot to take pictures.
Old 01-28-2007, 12:08 PM
biojim's Avatar
biojim biojim is offline
Talking 14 bolt
To put a 14 bolt ff in my 82 cherokee I don't have to move my spring pads??
1989 GW 4" lift
1988 GW (parts)
1982 Cherokee 6",35's 44's, 205, 727, 360 (never ending project)
1964 J Truck on Cherokee frame D 60's Th 400 203/Part time kit 500 ci Cad.
Old 01-28-2007, 07:02 PM
malodin's Avatar
well, i know i didnt have to move my springs pads, but thats on a 77, as long as the leaf springs are in the same position as my 77 and you get the same 3/4 77 ish chevy truck i dont see you having to.
took my rig out for the first time saturday, after the th400 rebuild, d300 swap and 14ff swap, no shocks yet, went over plenty of speed bumps and bounced but no stiffness anywhere.
Old 01-29-2007, 10:26 AM
biojim's Avatar
Talking
thanks for the info. The 82 cherokee should be the same width and the 14 bolt is the 1 ton verson but its a 79
1989 GW 4" lift
1988 GW (parts)
Old 01-31-2007, 08:55 PM
malodin's Avatar
im sure its the same. if you have any questions ask me, as i just made my disk brake brackets.
Old 01-31-2007, 10:54 PM
Heep80's Avatar
Heep80 Heep80 is offline
how diffucult would was it, besides the grunt work involved? I have a parts truck in SD, 80 3/4 chebby with a 14 bolt.. so i'm trying to plan ahead.
80 J-10 with 3in RC lift,1 in. shackles, buckshot M/T 33's. dual glasspack exhaust,eldobrock intake/carb/valve covers/aircleaner k&n, autometer tach, spare tire mount w/ fullsize spare,tool box, 40gal spare tank, grant steering wheel, rhino grill,DPA (Not installed Doug T's Headers, Hi lift jack, cobra cb,tie rods, & dual timing chain
