Old 03-13-2017, 06:50 PM
davidtwelsh's Avatar
davidtwelsh davidtwelsh is offline
Tailgate window half on/half off track - special kind of stupid
Tailgate window half on/half off track - can't open
I loaded a double oven in back...I guess I didn't slam the tailgate home because the oven pushed the passenger side of the window out of the track (to the outside)...driver side remains within the track.
The window won't go down more than 5".
searched site but all I can find is the usual dead motor/bad wiring.
any suggestions? thanks
1991 Grand Wagoneer
6.0L LQ4, 4L60e and np241c
4" lift, 2" body lift, razor grille, 4.11 gears,
Nitto grappler 33x12.5x15s
Old 03-13-2017, 08:59 PM
So you have an oven in the back, with the tailgate closed, the glass stuck 5" down, off the passenger track, and can't open the tailgate?
Not sure I can help, but can I just get a picture? Lol.
Old 03-13-2017, 09:03 PM
Have to figure some way to get it all the way back up and press it back over onto the slide.
Old 03-14-2017, 04:25 AM
It goes back up...which was convenient with the snow just dumping around here.
But it won't just pop back into the track.
I'm assuming I have to open up the tailgate panel and disengage the whole system.
1991 Grand Wagoneer
Old 03-14-2017, 08:17 AM
The bolts for the slides are on the outside of tailgate which is closed and inaccessible.
If you have an oven in the back I'd imagine you can't get to the access panel.
You have a small space to insert a pry tool at the top of tailgate and into the groove of slide and pull up and pry the metal window bar back onto the slide.
Old 03-14-2017, 09:09 AM
How hard have you pushed down manually while trying to lower the window to force it on down? Don't hold me accountable if the window shatters.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 03-15-2017, 02:54 PM
serehill serehill is offline
Gone,Never Forgotten.
well
The oven can move forward with the seat folded or removed
If you go inside & remove the tailgate carpet & loosen the window track screws you can probably get it down then open the gate remove access panel & fix.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-18-2017, 03:28 PM
What a temperamental beast.
After refusing to budge more than 5" where I had parked...
I moved her to a different spot...
Window rolled down fine. Able to open/close the tailgate. Window ran up with both side remaining in track...easily.
She must've been mad at me.
Thanks all...
1991 Grand Wagoneer
Old 03-18-2017, 04:06 PM
Lol.
I wonder how many people will try parking in a different spot now to try and fix their back windows when they get stuck....
Old 03-18-2017, 04:46 PM
I can only guess it was a different angle/pressure thing...my ex wife would say the same thing.
1991 Grand Wagoneer
Old 03-19-2017, 09:28 AM
Body flex, they are fairly prone to it on uneven surfaces.
I'd venture a guess w/ a 2" body lift you have more than w/o a body lift.
Old 03-20-2017, 08:54 AM
Engine-Ear's Avatar
Engine-Ear Engine-Ear is offline
I feel your pain...
...because I need to restore the wiring, the electric motor, tracks and weatherstrip on my tailgate ('82 Wag Lim)...
" So you have an oven in the back, with the tailgate closed, the glass stuck 5" down, off the passenger track, and can't open the tailgate?
Not sure I can help, but can I just get a picture? LOL." -ShagWagon
LOL! I was thinking the same thing.
1982 Wagoneer Limited 360 automatic
Inventor of the RediRad radio adapter.
Old 03-21-2017, 04:48 AM
I would've posted a pic but they never upload right...
1991 Grand Wagoneer
tailgate window c.v.paul General FSJ Tech 2 07-07-2010 02:46 PM
Tailgate window adjustment xtapa General FSJ Tech 3 04-27-2003 04:38 PM
Tailgate Window blt2krl General FSJ Tech 6 01-30-2003 09:45 AM
tailgate weather strip, rear wiper, "keep window up while driving" GED General FSJ Tech 3 07-28-2002 03:29 PM
Rear Window a Sticken JERRY88GW Body 0 08-02-2000 03:52 AM
