Old 02-25-2017, 10:06 PM
gpcl16 gpcl16 is offline
Wheel spacers?
http://www.bjsoffroad.com/Wheel-Spac...A_p_1509.html#
Anybody running these wheel spacers or similar? I would like to not have my front tires rub on my leaf springs when turning sharp. I have adjusted the stops but it kills my turning radius. I have a 4" spring lift and 31x10.5s. I want to keep stock wheels. I have heard a few horror stories from wheel spacers but as I understand it, wheel spacers generally only fail when they are torqued improperly or not re-torqued after driving a set milage. Seems like putting them on the rear might push the tires out far enough to hit the fenders when the suspension is stuffed?
1988 Jeep Grand Wagoneer
4" BDS Suspension Lift
Tru-Trac Rear
Howell GM TBI with Custom Tune
Old 02-25-2017, 10:51 PM
serehill serehill is offline
Gone,Never Forgotten.
To Each His OWn. I would never have them on mine.
There seem to be more good stories then bad.
http://www.ifsja.org/forums/vb/searc...archid=2097874
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-02-2017, 09:39 PM
mattparliament's Avatar
mattparliament mattparliament is offline
I run a similar product on mine on all 4 wheels, improved the stance and look, torque the correctly and they are fine, a non issue for reliability
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Old 03-02-2017, 11:42 PM
Spacers are always a bad idea. they dramatically increase the leverage on components . it's bubble gum and baling wire, there is a reason the factory never does it.
Get the right wheels with the right offset.
Old 03-03-2017, 08:57 AM
bkilby's Avatar
bkilby bkilby is offline
No difference running a 1.5" spacer or a wheel that pushes the tire/wheel out another 1.5". Same load, same leverage. Factory doesn't do it because they have tires and wheels made to their specs. There's nothing wrong with running good quality spacers. Been doing it for years.
Old 03-05-2017, 08:54 PM
alley oop's Avatar
alley oop alley oop is offline
no spacers
i would go with less backspacing on my wheels instead of spacers
Old 03-05-2017, 09:13 PM
There is a reason the factory didn't have wheels with 1 1/2" more backspacing. it's a bad idea, but if you must it's always best to use the right wheels.
Very seldom do modifications come without a negative side effect. sometimes it just takes a while before you find out you really aren't smarter than the engineers who built the original product. been there done that enough times I get it now.
Old 03-05-2017, 09:29 PM
Don S's Avatar
Don S Don S is offline
Gone,But not Forgotten.
The spacers will change the scrub angle of the front tires... in a slightly bad way... But shouldn't be to bad unless you play ditch'em a lot.
I used spacers a lot on several of my vehicles with zero problems.
Good luck.. Don S..
Sold our 1976 Wagoneer 406, MC4300, TH400, QT, TruTrac, 2" lift, 31x10.50s, duel Optimas,
It’s took us over 161 Colorado Mountain Passes, 3 Jeep Jamboree USAs & 2 Ouray Invasions from 1985 to 2010
ACRONYMS & ABBREVIATIONS HERE
Old 03-06-2017, 08:38 AM
draglink's Avatar
draglink draglink is offline
I've run quality 1.5" spacers with zero issues since 2007
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
Rear Wheel Bearing replacment How To Billygoat General FSJ Tech 12 04-18-2019 10:06 AM
Four wheel drive gremlin Andrew Love General FSJ Tech 17 06-01-2012 02:37 PM
WHEEL SPACERS FSJ-Earl General FSJ Tech 13 04-14-2008 08:57 PM
a few questions about wheel spacers... WRMorrison General FSJ Tech 3 09-18-2006 08:50 PM
Steering wheel off center after box swap? JeepsAndGuns General FSJ Tech 8 07-19-2005 03:21 PM
