Old 08-05-2016, 11:59 PM
Narrowed it down I guess
Howell $1300
FITECH $995
Hamilton $1400
I'm an intermediate driveway mechanic. Never done this before but willing to try.
I'm leaning towards the Fitech because of price and seems a lot less clutter and it seems you don't have to mess with the distributor. I've never timed a vehicle before but somewhat have the idea.
Upon reading and scouring for quite some time, Some say you need to mess with the distributor anyways and it seems there 100 mods that everyone argues about in lingo I don't really understand. I don't want to drill a hole in my distributor cap to make sure everything lines up right that I welded together and wired shut after I tap and die a screw that I ground down so it would clear the spinner mechanism. This just sounds like something I'd screw up really bad.
Howell and Hamiltons have a distributor with the kit already setup I suppose? Fitech claims will work with my stock one.
I'm also confused about if I need to buy a fuel sending upgrade. I'd like to upgrade but not sure what to buy here.
They all 3 seem to have a new fuel pump with kit but all offer other alternatives.
Fitech has some fuel command center can thing. I can't figure out what to do with it they say it's a fuel pump but it looks huge. Where would this thing mount? Seems a good thing to have? Does it make noise? They sell another inline fuel pump separately too and a linkage for $29. Would I need all these? That would put it over $1600.
Gas tank and fuel sending unit- I just put in a newly engineered fuel sending unit piece of crap from TGW that I had to mess with 19+ times to finally get it to work right. Would I keep all that the same or do I need a new gas tank with an in tank fuel pump so it's quieter on the end of my sending unit? And a lot of talk about changing my fuel lines to bigger ones rated for hi pressure.
Also should buy the the Doug Thorlel headers they sell on BJs and have them installed first? Does Doug Thorley come with a pre installed bunghole? I was thinking to order them and have a muffler shop install them and put in a o2 bunghole so I could just screw in the o2 sensor, or should I attempt this install myself and drive down and have them install the bunghole. Seems easy enough to do but seems easy enough to not get a good gasket seal.
I'm trying to plan this thing out so that I can order everything at once and only have to do it once and not be missing anything, and get it right.Never done something like this so I could use some advice here on a list because I'm not quite sure all I'll need. I'll just go through their instructions step by step so hope they have good ones.
Thanks
Stock 87 GW.
Old 08-06-2016, 07:31 PM
BigOberg's Avatar
BigOberg BigOberg is offline
oh i wish i had a cool handle.......
Check out my build. I went with the Howell and it was well worth the money.
Follow my build http://www.ifsja.org/forums/vb/showthread.php?t=174682
1989 Grand Wagoneer: 360-727-229, 4" BJ's Lift w/32's, Howell Fuel Injection, TFI Conversion
2012 Jeep JKU Sahara: 3" Lift & 35's
Old 08-06-2016, 09:02 PM
asudchiman's Avatar
asudchiman asudchiman is offline
I'd like to follow along. I too would consider the upgrade. At this point, it seems the Howell is one of the most popular. This may be because Wagonmaster uses it, but I am glad to hear all of the input.
Current Jeep Fleet:
1993 Wrangler Sahara (YJ) Stock, 52k
1991 Grand Wagoneer - [Black] 4" Lift, 32's, 92k
1991 Grand Wagoneer - [Hunter Green] Stock, 60k
1991 Grand Wagoneer - [Hunter Green] Restored (for sale)
Four Wheel Trends
Old 08-06-2016, 09:23 PM
asudchiman's Avatar
I have read your build thread many times. Good stuff!
Are you still using your Jeep as a DD?
Do you have any "lawnmower" smells from your Jeep? I ask because the carb smell is triggering migraines for my wife. My hope is that EFI with a closed system will eliminate the smell and make it more like a modern car.
Your thoughts would be appreciated.
Current Jeep Fleet:
Four Wheel Trends
Old 08-07-2016, 01:04 PM
BigOberg's Avatar
I haven't been using it as my daily driver now. Only because my new job came with a brand new company car. But I still drive the GW on the weekends and any chance I get. I went a good six months though driving her daily with no issues. As far as the Howell goes I do not have any fuel smell at all.
Old 08-07-2016, 06:00 PM
babywag babywag is online now
If your rig is truly stock w/ 2bbl carb?
You can add a 4bbl intake, valley pan gasket, and misc. to $ total/list.
Old 08-07-2016, 07:14 PM
I read it before. Looks nice. I re read it again. Not too much on the process. Did you change your gas lines? They looked bad in the pic. You mentioned you were going to do a write up when you had the time about the Howell. How is the distributor they sent you? We're the instructions easy for it?
Old 08-07-2016, 07:30 PM
I'm not too sure but I think so. Can you tell me what I got here?
Old 08-07-2016, 07:33 PM
Yep 2bbl intake & carb.
If you go GM TBI they come with adapter to install on stock intake.
If you go fitech you will need a 4bbl intake manifold.
Old 08-07-2016, 10:16 PM
Well that's good to know.
How hard is it to find an intake manifold? And is it hard to install? Seems simple if I'm already there if it's not to spendy.
Old 08-08-2016, 07:54 AM
asudchiman's Avatar
Thanks! That is what I was hoping to hear.
Current Jeep Fleet:
Four Wheel Trends
Old 08-08-2016, 11:07 AM
I need this one? Not sure what I'd be getting here but seems like a good start. Not sure how much more I'd have to put into it to get it going.
http://www.ifsja.org/forums/vb/showthread.php?t=180119
Or this one? $275 seems reasonable price.
http://www.jegs.com/i/Edelbrock/350/2131/10002/-1
Seems I have an 87 which is different. Am I pre pollution control? Not sure . Seems they made a change between 86-87 for Intake manifolds. Don't want to get the wrong one. What am I looking for here.
Maybe some other option for a manifold I don't know of like used or off another truck or something..
Thanks
Old 08-08-2016, 11:24 AM
Do NOT need 1st one. That is modified for MPFI.
You can buy new via summit/jegs, or used.
Post in wanted section or watch eBay and CL for used.
They run $100-$150 used, just be sure it is in good shape.
No stripped bolt holes or messed up gasket/mating surfaces.
If buying new I like this manifold.
https://m.summitracing.com/parts/ofy-5917
I think it would do well with FI.
But Edelbrock performer is fine as well.
Old 08-08-2016, 05:00 PM
That one looks good but says not available till march 2017...
FITECH is starting to add up to about $1700 out the door with the $300 manifold and $400 In gas command add ins..
Old 08-08-2016, 06:12 PM
Again just my opinions...
You don't need the $400 fuel command center, or the $250 fuel system.
A decent pump, and filter will do the job just fine.
You can get a walbro for ~$75 and a corvette regulating filter for ~$40(if going with returnless fuel system) .
Or you can buy an OE style pump for less.
The fuel command center has a 340 L/PH pump that is more suited for a 600-900hp engine.
IMHO the 600hp system is way overkill...4 80lb injectors.
The 400hp system is also mildly overkill, but not nearly as much.
Just like with a carb that is too big, a FI system that is too big will not perform optimally, but it will work.
You'll have to decide if a color touch screen, and timing control are worth the extra $$ to you?
Just don't get all sucked into the marketing hype.
Old 08-08-2016, 07:44 PM
Yeah I really appreciate your opinion. Always nice from someone who's been there, done that...
Especially when there's soooo many choices and everyone seems to do it a different way.
I just found a Holley Sniper that looks pretty good for $1k. Says it bolts up to 2 and 4bbl manifolds but it's out till October... Holley has been around some.
I was planning to pull the trigger on the FItech yesterday, but was only planning on around $1400 and that's saving by doing it myself.
Not so sure now that I would have to buy and install a different manifold. SURPRISE!! Are they easy to install? And is there any " might as well do this" while we're in there? Seems like there always is.
Also curious on the Howell and Hamilton. They offer distributors with their kits. Are these upgraded better distributors to handle FI? Or just modified stock ones? And would I have to upgrade whole ignition system on top of the kit? Like a new coil, wires, ignition control box... Or is it just more like not neccesary but you should? I had a hi performance ignition module on my parts donor I switched out a few weeks ago when I learned what an ignition module was and the motor won't start with a bad one. Would this one work okay enough?
Old 08-13-2016, 02:33 PM
A 4bbl is an upgrade vs. the stock 2bbl, there is nothing especially hard about installing one. There is nothing "while you're in there" to do when installing an intake.
To take advantage of timing control a modified distributor is required.
The stock Motorcraft distributor can be modified to use pretty easily.
What system you run determines what needs to be upgraded/replaced/added/etc.
Your swapped high performance module is just a module, nothing really high performance about it.
Howell kits do not come with a distributor AFAIK, they also don't control timing. You can probably add these options on, but it would be extra $$.
Bill's system does timing control, and comes with a distributor.
No suprises, no extra parts needed AFIAK.
Fitech is probably going to be the most expensive option, as you've already found out.
Old 08-14-2016, 02:14 PM
cjsrebiff's Avatar
cjsrebiff cjsrebiff is offline
I don't really post much, but I thought I would put in my .02. I have the Howell system. Did some reserch prior to purchase. It is an extremely easy bolt on. Everything was clearly labeled and instructions were laid out very well. I dropped in a new engine and the support from Howell was great. Letting me know if and what I needed. I made my decision after talking a friend that works at Warn. They know a little about off road performance.
Also, on something like fuel system, i wouldn't shop by price. It will cost more in the end.
1984 Grand Wagoneer - Howell TBI, NV241, 6" Frankinlift, Detroits front and rear, Warn 8274 , 35 MTRs and soft leather
Old 08-14-2016, 10:17 PM
John N John N is offline
Noob!
I have a Howell on my Scrambler with a 360. Between that, a DUI HEI distributor and an Edlebrock Performer intake, it's been really reliable. I installed it all myself. The only issues initially were vacuum leaks that had to be chased down. It runs great and starts easily.
Old 08-15-2016, 12:30 PM
darylb darylb is offline
Different headers
I would stay away from the Doug Thorley headers. Yes, they will weld the bung in for your O2 sensor, but their design is garbage. The header flange is cut so that the holes for the ports are way too small, it cuts about 15% or more of the exhaust flow right at the manifold. And they have already ground out all of the extra material they could so you can't improve the flow any further.
I have plenty of pictures to show what I mean. When you complain to Thorley about it they say that you will only lose 4 to 7 horses and you really don't need them for your application.
There is a header thread on here that goes through the other headers, stick with one of those. You'll save money and get much better headers.
http://www.ifsja.org/forums/vb/showthread.php?t=151504
1973 J4800 - 401- TH400 Novac Stage 2 - D20
Best guess: How much does a Cherokee body weigh? Strode General FSJ Discussion 3 01-06-2012 06:13 PM
Ouch... guess it's time for an upgrade olllllo General FSJ Discussion 12 03-31-2011 08:32 AM
Guess It's Gone. jeeper54 General FSJ Discussion 21 03-23-2011 08:02 AM
Running Problem Narrowed Down!!! Thumper168 General FSJ Tech 7 01-13-2011 11:57 PM
You'll never guess what I found in my axletube today... DanHS General FSJ Tech 7 08-29-2005 04:20 PM
