Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Closed Thread
  #241
Old 01-05-2016, 01:11 PM
2ndrad 2ndrad is offline
Noob!
Talking harness
SERE need one for an 86 J20 to 29824.
SI VIS PACEM PARA BELLUM
64,74,84x2 Grand Wags
76 J10, 86 J20, 72 CJ6
  #242
Old 01-07-2016, 10:12 AM
serehill serehill is offline
Gone,Never Forgotten.
Hello
I responded to your PM
Thank you & lets talk.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
  #243
Old 01-08-2016, 08:10 PM
letank's Avatar
letank letank is offline
Originally Posted by Jughead
Absolutely fantastic design and quality product! I highly recommend this upgrade. It gave me an excuse to pull the entire grille and get rid of 39 years of dirt and grime. Stock headlights on high beam nearly as bright as the headlights on the wife's 2010 Yukon!
Kudos to a great vendor!
Same here, took me more time to remove the rust and fix some holes than install the wires.
Finally had the time to test the light in full night time... very very bright... I may not need to install the H4 hella for some time.
Michel
  #244
Old 03-05-2016, 11:37 PM
blazer3664's Avatar
blazer3664 blazer3664 is offline
A kit for a '81 Cherokee?
Stock except for pie plate lights set to come on with high beams. Pie plate lights are generic, and would not need a connector, as they will be soldered and adhesive heat-shrinked.
Thanks,
Jim
modified flares, removable top, OBA w/200psi tank,
LQ4, 4L80e,NWF doubler w/upside down 203
SOA w/ D44s F+R for now
H1 wheels+tires (cut), hydroboost brakes
custom shackle flip
W/F150 springs
-----Coming Soon-----
snorkels,
OX'd D60/14B-FF
  #245
Old 03-06-2016, 08:52 AM
blazer3664
PM Sent
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #246
Old 03-23-2016, 06:33 AM
Zorm's Avatar
Zorm Zorm is offline
serehill, need one for a 83 Cherokee. Actually may take yours apart to splice into another. Installing a 4.7 sroker 6 cyl I built, and I'm using the engine wire harness from a 92 little Cherokee. I guess my thought is, where is the power coming from with our old Jeeps? In this 92 harness, I have a separate larger gauge wire for the headlights.
just need to wrap my head around the power flow for all this.
thanks
83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
65 Corvair Corsa Convertible, 4 speed, 140 quad carb engine
71 F-250 Camper Special (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
  #247
Old 03-24-2016, 05:12 PM
63J200atLSU's Avatar
63J200atLSU 63J200atLSU is offline
COUNT ME IN!
Got a '63 J200, pretty sure the whole system from the plug on the switch to sockets is bad, dimmer switch too. Lots of frayed wires and melted plugs. Don't want to go burning Walter down just as I've got him running and the brakes working! Let's talk and figure out what I need. PM sent.
'63 J200 Resto-mod in progress
(http://www.ifsja.org/forums/vb/showthread.php?t=178651)
If all goes well, we can toast to accidental successes.
I'm convinced I'm just too dumb to know that I can't restore this old truck...
  #248
Old 03-31-2016, 08:45 PM
BadRat's Avatar
BadRat BadRat is offline
Awesome quality harness, easy-peasy installation, and can now actually see at night!
couldn't ask for a better...not to mention safer...upgrade
Thanks Serehill!!!!
Kurt; but you can call me anything you want, except late for dinner
1988 Jeep Grand Wagoneer
Hand me that doo-hickey wrench thing, and a beer
  #249
Old 04-06-2016, 05:59 PM
Lake Ripley's Avatar
Lake Ripley Lake Ripley is offline
Noob!
78 J10
I would like to upgrade to your headlight harness. My PM got kicked back.
Thank you
'78 sunshine yellow J10
  #250
Old 04-10-2016, 07:10 PM
steve578's Avatar
steve578 steve578 is offline
PM sent.
  #251
Old 04-10-2016, 07:44 PM
OK
Thank you
PM'd you lake.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #252
Old 04-10-2016, 07:45 PM
Yessir
Originally Posted by steve578
PM sent.
PM'd you Steve.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #253
Old 04-10-2016, 07:47 PM
Thanks Serehill!!!!
Thank you sir there is no comparison just cheap imposters, with zero tech support no customization & no warrantee. It's great to be the best.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #254
Old 04-14-2016, 02:02 AM
Mike7009's Avatar
Mike7009 Mike7009 is offline
Finally getting around to doing this, just wanted to say you have another satisfied customer. Fits great, very easy upgrade. I haven't got a chance to really test the lights out yet but I'm sure it's gonna be an improvement.
-74 Cherokee 360, qt part-time, 4" lift 33's
-90 waggy, soa w/ford f250 axles
-Subaru legacy gt wagon. turbo
-2012 tundra trd rock warrior
  #255
Old 04-14-2016, 06:50 PM
I hope so & thank you. Even if you can't see the improvement which is rare knowing your headlight switch dimmer & wiring will live a lot longer is well worth it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #256
Old 05-08-2016, 08:45 PM
Bearman Bearman is offline
I sent you a PM regarding a harness. I have a friend needing one.
81' Jeep J10 currently restoring piece by piece
  #257
Old 05-09-2016, 09:28 AM
Dave740's Avatar
Dave740 Dave740 is offline
Looking for a quad headlight setup for a 91 GW.
1991 Grand Wagoneer
Hunter Green Metallic
Silverdale, WA
  #258
Old 05-09-2016, 03:20 PM
Hello
I responded to the tailgate harness request with my info & thanks.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #259
Old 05-09-2016, 03:22 PM
well
PM
Sent
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
  #260
Old 05-27-2016, 09:15 AM
Coyotesrus's Avatar
Coyotesrus Coyotesrus is offline
I need one
For an '89 GW. Should I upgrade the lamps to Hella European while I'm at it?
The Jeep is cheap. It's the upgrades that'll kill ya.
Closed Thread
Poll- Interest in custom Safari Rack? Walt General FSJ Tech 22 01-06-2016 05:01 PM
Gauging Interest - Ignition control Dizzy's? Billygoat Fuel Injection 2 10-01-2011 06:03 AM
Gauging Interest 1986-1988 J-truck Fuel Sending Units TPICherokee General FSJ Discussion 26 12-04-2010 07:33 AM
Gauging Interest - EFI rawdave General FSJ Discussion 6 08-25-2008 05:43 AM
